Coolant Temperature Sensor question
Old Dec 26, 2018 | 06:30 AM
jgcable's Avatar
The temp gauge on my 1997 suddenly stopped working. It just reads cold all the time. Car is running fine. I suspect its the Coolant Temp Sensor. Is it normal for the car to not throw a code for it? Mine didn't.
Old Dec 26, 2018 | 07:36 AM
dsonnylal's Avatar
If you have access to a scan tool with a live data feature, you can verify if your CTS is working or not. Could also be an issue with the gauge cluster.
Old Dec 26, 2018 | 08:27 AM
Turbobink's Avatar
Keep in mind that there 2 sensors in the 4th gen..
One associated with engine management, the other related to the operation of the temperature gauge.
https://maxima.org/forums/4th-genera...e-problem.html
Old Dec 26, 2018 | 10:52 AM
jgcable's Avatar
So.... does a coolant temperature sensor cause a check engine light to go on if its faulty? I would think no. Only the other sensor that goes to the ECU would cause a SES light to trip. Why would my ECU monitor what gauges are working? That's my thought.
Old Dec 26, 2018 | 11:01 AM
JvG's Avatar
JvG
Again, there are two sensors.
the ecu wants to know what the water temp is.
That's the ects. Engine control emperature sensor.
a faulty one would throw a code.
the second sensor reports to the guage on the dashboard. It would not throw a code.
Old Dec 26, 2018 | 01:24 PM
Turbobink's Avatar
Think of the ECT sensor as just that ... an engine management “sensor”. The failure of an engine management sensor will create a DTC.
Think of the gauge sensor as the coolant temp “sending unit”. The failure of a sending unit typically won’t result in the generation a DTC.
If you’ve got a DTC that points to the ECT, I’d recommend replacing it ... they’re cheap.
If all you’ve got is a malfunctioning dash gauge and no DTC, that would appear to point to the “sending” sensor or a gauge related electrical connector.
TWINTRBO
Nov 4, 2010 04:46 PM
laylow1988
Aug 17, 2006 07:35 AM
krazy
Nov 1, 2003 08:01 PM
jaredb03
Sep 19, 2002 10:07 AM
mohfo
Jul 6, 2002 12:23 PM
