Long story short I got my hotshot headers back after waiting since October and it's time to get this 2k14 engine 2k3 ECU swap finished. I got a few small odds and ends on their way and I wanna start getting everything prepped and ready to go.
Maybe some of you showroom neat freaks can give me some tips on how to prep this ugly engine bay to actually be able to show off my swap. It's in the garage and it's winter in Ohio so not sure the dawn soap and hose rinsing would be the go to, maybe I'm just over thinking it
I've found that kerosene/ dawn mixture works great, and is water soluable.
1 part dawn per 9 parts kerosene.
I'd definitely listen to this guy.
I do Simple Green sprayed on full, then scrub and rinse with water. Then soap and water until clean. All of this is out of spray bottles (not a hose). I use choke cleaner on engine and trans cases followed by the same Simple Green / Soap and Water application.
i know my engine bay is clean because i randomly clean it up at least twice a year. even though it's been sitting for a few months, i still have popped the hood and wiped it down because i hate a dirty engine bay/engine.
This stuff is amazingly strong even when diluted! AND (for Tb) It's biodegradable. However, do not even think about not using gloves. It will remove every drop of oil from your skin and they will crack painfully after a little while of use.
The key is some sort of friction with any cleaner or higher pressure water force, or some dirt/oil residue will remain.
I'm trying to avoid a hose it being below freezing everyday and the car is inside the garage. I think I'll go with a spray bottle of water and simple green with a rag to do the friction work
Best cleaner i have ever used is POR 15 marine clean. Works great for carpet and headliners.gets anything out. Cuts grease like crazy. I have tried everything. Makes dawn look like junk.
I dilute it 50/50. Took my headliner out that was in the car fire. And it got it clean like new.
Just a warning don't put it on finished aluminum and finished plastic. it will etch it.
