Camshaft position sensor change.
Old Jan 20, 2019 | 11:52 AM
discobiscuit's Avatar
Have a 95 Maxima and got an error code to replace the camshaft position sensor so I Bought one from Autozone. I could also see a small oil leak from around the sensor as well I took the old one out but when I tried to install the new one it would not seat completely up against the engine.
The O ring on the old sensor is flat and I can see where the oil leak is coming from. the O ring on the new sensor is nice and round but this is what’s stopping the sensor from going in all the way.
How do I solve this problem?
Old Jan 20, 2019 | 12:40 PM
Turbobink's Avatar
Apply a little Vaseline to the O ring and try installing the sensor with a little back and forth twisting motion.
Old Jan 20, 2019 | 01:49 PM
I put a little engine oil around the gasket and tried twisting the sensor while pushing REAL HARD but that dang thing REFUSES to go in.
SHOOT DARN HECK!
Old Jan 20, 2019 | 03:49 PM
Turbobink's Avatar
If you've got a heat gun or a blow dryer handy carefully heat the O ring.
Remove the O ring from the sensor body and heat it up to soften it a bit. Be cautious, don't burn or melt it. Don't heat the sensor ... just the O ring.
Quickly install it back on the sensor and install the sensor in the timing cover.
Old Jan 20, 2019 | 05:06 PM
GREAT IDEA! Thanks for the tip
knock
Feb 6, 2015 11:05 AM
hornepirate
Mar 17, 2010 04:47 PM
