Will OEM Ignition Coils From A 1997 Maxima Work In A 1999 Max?
Old Feb 15, 2019 | 10:04 AM
uk21's Avatar
I’m assuming they would but just wanted to check first before I bought them. I’m going through the whole p300 and p1320 deal right now. I’ve searched here and google but haven’t been able to find an answer on this. Thanks!
Old Feb 15, 2019 | 10:29 AM
Turbobink's Avatar
The Nissan P/Ns are the same for the '97 and the '99 ... 22448-31U01 (rear) and 22448-31U06 (front)
Old Feb 15, 2019 | 10:31 AM
Catalysts's Avatar
I’m no expert but yes coils from all 4th gen maximas are interchangeable. The coils from 99s are said to have a lot of issues from what I’ve heard. Pending you get new coils or ones that came from another max, make sure to figure out if you can, what coil(s) are the issue. Many say to take a coil out while the car is running if the engine power suffers, that coil is okay, if it doesn’t change that’s probably your issue coil. The front coils are different from the back coils so make note of that as well. Make sure that if you’re looking into your engine bay from the front the coils are ordered:
1 3 5
2 4 6
coils 1,3, and 5 are different from 2,4 and 6.
Old Feb 15, 2019 | 11:20 AM
Shrout1's Avatar
I've been using Autozone coils for almost 30,000 miles and I haven't had any problems. I know folks here emphasize OEM coils but they seem hard to find or super expensive. So long as I know what cylinder is misfiring I'll just keep going to Autozone!
Old Feb 15, 2019 | 11:29 AM
Catalysts's Avatar
I would agree completely, not to hijack the thread but the one I odered from autozone came with a lifetime warranty but was more expensive by $30 than a hitachi I ordered from Carid, granted the hitachi doesn’t have a warranty as far as I’m concerned.
Old Feb 15, 2019 | 11:46 AM
uk21's Avatar
Thanks a ton for help guys! Just wish I had gotten the used oems before spending hundreds on aftermarket coils that won’t even work right.
Old Feb 15, 2019 | 12:14 PM
PH98I30's Avatar
Junkyard OEM coils are great. I can usually buy 4-6 from a boneyard for the price of one new one. If a couple of them are no good, I still come out ahead. However, all of the ones I have gotten were good. The wrecked car was obviously running for it to be in the junkyard. If the coils were bad it probably wouldn't have been on the road. Hitachi, Hanshin or Mitsubishi seem to work well.
Old Feb 15, 2019 | 03:55 PM
Shrout1's Avatar
I have heard this too! The nice thing about the coils is that they are super easy to replace, so the risk of a junkyard coil or getting a cheapo won't cost you a lot of time fixing it When I did my rear fuel injectors I sprung for the more expensive Hitachis because I didn't want to have to dig back in there.
Old Feb 17, 2019 | 07:59 AM
CS_AR's Avatar
Hitachi Automotive Systems Hanshin Ltd
It reminds me of General Motors, Delco, Remy, and Frigidaire from the good old days.
Hanshin Electric KK manufactures automobile parts. The Company develops, produces, and sells automotive ignition coils and electronics. Hanshin Electric also manufactures and sells home appliances and housing equipment.
https://www.bloomberg.com/profiles/c...ms-hanshin-ltd
Old Apr 17, 2019 | 11:01 AM
ermias01's Avatar
Cleaned up my OEM Ignition coils - 1999 - 2002 Maxima SE
Just sharing if it helps someone trying to address the pesky P300 misfire issues. While swapping out ignition coils - I opened up one of the bad ignition coil - and did very basic clean up job - and surprisingly it seems to have cleared the issue. See attached pictures for more details.
It goes without saying this is NOT a guaranteed solution - but it certainly saved me few $$$ once I did this simple clean up on the rest of the i.coils. Basically I opened the plastic boots that covered the internal springs, fuse and fuse contacts - brushed / cleaned the contact ends.
Cheers!
Disassembled 1999 - 2002 Nissan Maxima Ignition Coil.
JAY MCKENZIE
22
Sep 7, 2012 07:33 PM
Recarta
Aug 20, 2012 04:13 PM
edwardh1
20
May 31, 2011 12:45 PM
Sky_99
Dec 28, 2004 03:44 AM
vipervadim
Dec 24, 2003 07:38 PM
