what color wires go where?
Try this site:
www.installdr.com
www.installdr.com
You should have gotten a wirering harness. These take about ten minutes to put together and are pretty much idiot proof. They hook directly up to the factory harneses. Kind of like plug-n-play. If you have any ??? give me an e-mail and I would be glad to help
I am in the process of gathering all the info to install a new HeadUnit for my Maxima as well.
The two harness are listed below;
Metra harness # 80-1763 Metra Brand,Nissan Head Unit Wiring Harness,
I've been told this one can be had at Best Buy
Metra adapter # 40NI10 Metra Brand, Nissan Head Unit Antenna Adapter
I've been told this one can be had at Circuit City
Hope this helps.
White96MaxSE
Hope this helps.
White96MaxSE
Hope this helps.
White96MaxSE
Hope this helps.
White96MaxSE
Originally posted by 98BlaximaSE
The site no longer has stuff for Nissan's.
Some of the sections are still being updated. What exactly are you trying to do? I may be able to help. If you are just looking for some How2 on removing your existing system. Try http://carstereohelp.com/stereoremovalNisMax2.htm
what i am trying to do
i have bought a aftermarket deck and new components for up front and new speakers for the rear deck. Iam wanting to take out the bose system in the rear deck. there is 4 color wires that go with the factory bose system. I do not know what colors i need to use.??
Re: what i am trying to do
Just FYI
Here's how to get to the rear speakers.
http://forums.maxima.org/showthread....=rear+speakers
I went to Circuit City to check into the wiring harness and antenna adapter.
The guy at Circuit City raised a question I need answered.
Will the Antenna adapter that we are referring to from Metra (Part # 40NI10) retain the diversity antenna functionality of the dual antennas?
They told me I would lose that ability and I'm not sure.
TIA,
White96MaxSE
TIA,
White96MaxSE
TIA,
White96MaxSE
TIA,
White96MaxSE
On the front of the BOSE Double DIN head Unit it says "FM Diversity"
and it is my understanding that the Head Unit? has electronics included that allows it to detect which of the two antennas (the automatic mast at the rear of the car or the one in the rear windows) is picking up the stronger signal and automatically switching to that antenna.
This makes it better at reception given changing conditions as you drive down the road then just a single antenna.
Do you think the aftermarket head units on the market today are able to utilize this dual antenna configuration, or maybe it is another electronic component prior to the head unit that performs this function?
It would be nice to know.
Thanks,
White96MaxSE
Thanks,
White96MaxSE
I am no expert but I would think that today's aftermarket head units are superior to OEM units. Although I am sure not all of them support this FM diversity/dual functionality I still don't think the harness will interfere or somehow eliminate this function of the ?head unit?. I wouldn't worry about it too much because many people have successfully changed their head units and used the harnesses.
Thanks,
White96MaxSE
I went to Best Buy's Car Stereo location today and the installer there
told me that the window antenna would likely not be used in the aftermarket head unit.
I am looking at a couple of the Alpine Head Units for my car.
Anybody know anything more about the "FM diversity" feature built into the BOSE Head Unit?
Thanks,
White96MaxSE
Thanks,
White96MaxSE
If you really must find out try contacting someone at www.crutchfield.com maybe they can help.
Ryan
White96MaxSE
White96MaxSE
Ryan
Originally posted by StaindMaxima
I installed a Kenwood P907 in my car and reception improved if anything. I install all day long (its my job) and have never experienced any reception losses when adding aftermarket headunits in Bose equipped Maximas regardless of what brand I installed.
Ryan
Ryan
Thanks for your comments. I bought the Metra 40-NI10 Antenna Adapter today which says on the package that it is a Nissan Antenna Adapter cable. It says right on the blister pack that it is a "Nissan diversity antenna with 2 pin plug to universal radio plug".
It has a large jack with two pins in it (female) that probably accepts the male Nissan Diversity Antenna plug that is currently plugged into the back of the Bose Head Unit. On the other end it has two wires. One terminates with a male universal antenna plug and the other end terminates with a female universal antenna jack.
This all looks well and good.
Yep, Attention to Detail and Planning are part of my nature.
Thanks to everybody for your advice.
White96MaxSE
White96MaxSE
White96MaxSE
popdedop
09-11-2015 11:17 AM
