bad charcoal canister or leaking injector(s)??
Old Mar 10, 2019 | 02:40 PM
max ride 41's Avatar
after what seems like an eternity of trying to get maxy back up and running right, i was reading that a failed charcoal canister or the valve in front of it can get clogged or stuck shut. i am going to check the front 3 injectors this week if possible, but i read that topping off your gas makes the canister fill with gas causing the gas smell. i don't do that, but will a 24+ year old canister and/or valve cause my problem ( smoke and gas smell at start up ), or are the injectors ( that i have no codes for ) causing the issue? i know many of you want to say injectors, but, 4 of them are new, and 2 of them are about 2 years old with no codes. i truly hate to start a new thread, but i am so frustrated with this problem after all i've done to maxy she should run perfect. where to get new canister and valve in front of it that that are reasonable and cheap, thanks
Old Mar 10, 2019 | 03:33 PM
Zerodrag's Avatar
If it's the model where the charcoal cannister is located at the back of the car (on driver side), it is pretty cheap brand new from the dealer.
https://www.courtesyparts.com/oem-pa...bC12Ni1nYXM%3D
Old Mar 10, 2019 | 04:13 PM
JoshG's Avatar
Is there any shops around willing to diagnose ur car? I feel like you are trying so hard to fix this problem yourself but can't seem to figure out what it is. Best of luck to you.
Old Mar 10, 2019 | 06:59 PM
reallywildstuff's Avatar
Its faiirly easy to pull the lines off the charcoal canister behind the driver’s rear wheel and check it - if there’s charcoal falling out of it, well then theres your problem.
There will also almost certainly be charcoal all the way up the line to the valve on top of the intake that it all connects to...you have to take it all apart and blow the charcoal out the line, plus replace the chacoal canister.
i made a thread about this not that long ago, look for my username and EVAP...the charcoal canister fails internally due to age.
Old Mar 10, 2019 | 07:12 PM
Originally Posted by reallywildstuff
Its faiirly easy to pull the lines off the charcoal canister behind the driver’s rear wheel and check it - if there’s charcoal falling out of it, well then there's your problem.
There will also almost certainly be charcoal all the way up the line to the valve on top of the intake that it all connects to...you have to take it all apart and blow the charcoal out the line, plus replace the charcoal canister.
i've been to a couple of op around here including 2 dealers, i really feel like all they want to do is sell me a new car or mis-diagnose the problem. i was taking her to this one guy who wasn't charging me a lot but also didn't seem to grasp what i want which is to fix the car. charcoal canister being that cheap i'll probably replace it because i'm an idiot and i like throwing money out the window. plus i think that the fuel pump is on it's way out cause of the age and all the problems. goddamnit
Old Mar 11, 2019 | 04:52 AM
Turbobink's Avatar
... charcoal canister being that cheap i'll probably replace it because i'm an idiot and i like throwing money out the window. plus i think that the fuel pump is on it's way out cause of the age and all the problems. goddamnit
I'm going to scold you again, grasshopper, for these sentiments.
If you're going to keep (and actually drive) a 20 to 25 year old car, parts will need to be replaced ... sometimes simply for the sake of replacing a 20 to 25 year old part.
Replacing a 20-25 year old carbon canister, notwithstanding it's potential failure, is smart.
Ditto on the fuel pump (I've actually got one of these on the shelf in the garage) myself.
Your car's insured (as in you keep an auto policy), right?
This is the pretty much the same thing.
Old Mar 11, 2019 | 06:51 AM
M in KC's Avatar
Make sure to blow all the evap lines out when replacing the canister, from the engine back to the canister.
Old Mar 11, 2019 | 09:25 PM
i know man, i'm just feeling like it's never gonna end. i was thinkin on doing the ects because i think at 14 years old, it probably needs replacement. am i right in stating that they don't always throw a code?
Old Mar 11, 2019 | 09:42 PM
Violator's Avatar
Right on the ECTS and a good idea. Over the next 5-10years you'll probably of replaced most if not all the sensors and other wear items. But then it will be a born again Maxima
Old Mar 11, 2019 | 09:53 PM
JoshG's Avatar
I'm still thinking it's your injectors.. are they flowing properly and not stuck open?
Old Mar 12, 2019 | 03:47 AM
just curious, you stated that your spark plugs were black. how old were your injectors that you replaced? what did you do to test before pulling them? my plugs are black, don't really want to pay to re-do all the injectors. i know they're not all bad, maybe a couple of them. i fired up maxy yesterday and she ran like cat ****, tons of smoke, stalled after only driving a couple of miles with strong gas smell. i really wish i knew someone from this board that could come over and give me a hand with the car, bad back and shoulder and i can't bend over to pull apart the max. i have a new guy, but he's so f'ing busy all the time i can't get him to work on maxy. it's like pulling teeth. i have cash if someone wants to stop by and help before may when the inspection is up.
Old Mar 12, 2019 | 05:24 AM
Turbobink's Avatar
Although I do have the benefit of having three vehicles at my disposal and you may not, I personally am all about the "phased approach" if you can go that route.
Replace your carbon can ... see if that does it. But, be prepared for the possibility that it's not truly the problem.
Replace your fuel pump ... see if that does it. But, be prepared for the possibility that it's not truly the problem.
I do still feel strongly, based on your previous descriptions, that your issue is very likely an injector issue.
Nonetheless, your investigation and replacement of old parts and pieces isn't stupid and it's not a waste of money.
I think you going after the ECU as the culprit should be your last option unless you've got some very compelling evidence pointing to that component. You've got a couple of much more likely causes staring you in the face that should, IMO, be addressed first.
Old Mar 12, 2019 | 06:28 AM
i would'nt even consider the ecu, no way. injector's are next after reading josh's description of his running rich and black plugs. i just want to know why all of a sudden those damn things go south like that. christ, i mean i replaced so much $hit on the max and all of a sudden she $hits the bed and won't run right?
Old Mar 12, 2019 | 07:25 AM
Turbobink's Avatar
She's 20+ years old ... that's 140 in dog years.
Old Mar 12, 2019 | 07:49 AM
Injectors or FPR.
Old Mar 12, 2019 | 03:39 PM
Zerodrag's Avatar
Are all the plugs black? If they are on all of them, I doubt it would be an injector issue and I would imagine it being more of a global fuel issue. If only individual ones are, then I think you could narrow down the issue.
Old Mar 12, 2019 | 05:31 PM
JoshG's Avatar
Injectors my dude, I went through the same thing. Flow test and make sure they're spraying correctly. Otherwise, the misfire comes back. I went through 7 brand new injectors before realizing they were all defective and did not know if they were flowing correctly in the first place. Before that, my injectors were the originals that came from the car (super dirty and dusty).
Injectors may have been defective right out of the box! cause that's what happened to me and I thought it was something else because of the smoke coming out of the exhaust. Do not overthink this before you start replacing parts that are not solving the problem. Black spark plugs is a big red flag that it is running rich, running like cat ****, fuel smell, and stalling. It is clear its injectors.
Old Mar 12, 2019 | 09:37 PM
meaning?
Old Mar 12, 2019 | 09:53 PM
Zerodrag's Avatar
Meaning something that wouldn't isolate to affecting individual cylinders (e.g. injectors, etc) but across all cylinders (e.g. MAF, etc).
David A
34
Sep 4, 2018 05:44 AM
Will92
Jun 15, 2017 02:04 AM
cmd26
28
Jun 22, 2014 08:30 PM
crashmanmike
Mar 28, 2004 07:57 AM
Dombkow
Sep 15, 2002 04:54 PM
