Battery light turns on a few minutes after starting
Old Mar 26, 2019 | 12:28 PM
ColeTrickle's Avatar
As the title says, battery light on my cluster turns on about 3 or 4 minutes after starting driving, and doesn't turn off until I stop the car. I haven't noticed anything else strange so far. The car starts normally and all the electrical system works well but my gauges -which were working bad long before this new issue-. Maybe it's something related with my alternator. I've checked the forum and it's said Nissan marks alternator issues with flashes on battery and brake lights, but it's not my case -althought I'm from Europe and maybe that rule dosen't apply here, idk-. Also, I've checked the battery and it shows 14,4V at idle, which I've been told it's OK.
Any suggestion? Thank you in advance.
Old Mar 26, 2019 | 03:27 PM
KP11520's Avatar
As a precaution, check for a blown 7.5 amp fuse in the box under the dash. IIRC, Left column by the bottom.
Old Mar 27, 2019 | 04:29 AM
Turbobink's Avatar
What's the battery voltage with the car not running?
Old Mar 27, 2019 | 06:24 AM
reallywildstuff's Avatar
Dont leave us hanging here guy - other people got the exact same problem...
Old Mar 27, 2019 | 10:45 AM
I get 12.54V
Old Mar 27, 2019 | 10:47 AM
Well, all fuses under the dash are cool, BUT I've found a blown 7.5amp fuse in the box under the hood, on driver's side. It's labelled as ALT.S
Old Mar 27, 2019 | 11:37 AM
JvG's Avatar
JvG
Well, replace it.
Old Mar 28, 2019 | 04:31 AM
Turbobink's Avatar
That's the "alternator sense" fuse.
It's associated with the voltage regulator and the regulator's function in sensing voltage from the alternator.
It makes sense that having blown, your battery light would illuminate with battery and charging system conditions being otherwise normal.
Old Mar 28, 2019 | 08:25 AM
Violator's Avatar
Old Mar 28, 2019 | 01:47 PM
I've replaced that fuse today, but it has blown again. Not sure if the cause of this issue is the alternator or a short somewhere.
Old Mar 28, 2019 | 06:16 PM
I can see - but what does this mean ?
enquiring minds want to know
i will look at my own ALT.S fuse when I get it back from body shop
Originally Posted by Violator
Old Mar 29, 2019 | 04:31 AM
Turbobink's Avatar
Prior to this issue did you do any work on the alternator ... replacement, wire disconnect/reconnect ... anything?
Old Mar 29, 2019 | 05:08 AM
Both battery and alternator remain the same since I bought the car, and I haven't touched any of the wires of them. I replaced my alternator belt some months ago because the old one was squeezing so much. Maybe something related with tightness of that belt?
Old Mar 29, 2019 | 07:17 AM
Turbobink's Avatar
This being the case, I think I'd go through, disconnect all harness wiring from the alternator itself, fully clean and surface each connection and reattach.
maximaham
Jul 13, 2017 01:01 PM
VQrebuild96
May 12, 2008 07:18 PM
zheka
Oct 3, 2007 05:23 AM
maxpwr2k1
Mar 13, 2006 03:52 PM
Rino1313
Oct 21, 2003 06:06 PM
