Rack & Pinion Boot Cover Torn..
Old Jun 3, 2019 | 11:46 AM
ukmastermind's Avatar
How worried should I be? The flexible cover (looks like a CV boot ) has torn. I see a good amount of oil under the transmission + engine but not sure if its pwr str fluid or just motor oil. Thoughts?
Old Jun 3, 2019 | 12:05 PM
Turbobink's Avatar
The boots don't have anything to do with fluid ... per se ...the boots simply protect the inner rods from debris, water, grit, etc.
A torn boot can allow debris, water, grit, etc. to damage rack seals resulting in a leak, but don't themselves hold, retain or seal in fluid.
What color is the fluid you see?
Gold/brown/black or red to red-ish?
Old Jun 4, 2019 | 03:12 PM
ok that's what i thought and the reservoir has barely gone done.
The leak is brown and I'm guessing it's motor oil. I guess the engine sprung another lead lead somewhere
Is it possible to just replace the rubber boot?
Old Jun 4, 2019 | 04:42 PM
KP11520's Avatar
You can replace the boot, but you have to remove the outer Tie Rod End from the Inner's threads to slide the boot over the shaft of the Inner Tie Rod and seat it onto the rack with Nylon Ties or something substantial. You can leave the outer tie rod attached to the steering knuckle.
Most would suggest an alignment even if you think you put it back where it was threaded on.
Old Jun 5, 2019 | 09:39 AM
ok. I'm going to look into this. Thanks for the info
Old Jun 5, 2019 | 09:57 AM
Turbobink's Avatar
https://www.stretchcvboot.com/rakboot/
Old Jun 11, 2019 | 09:51 AM
Have you used this product before?
Looks like a universal product
Old Jun 11, 2019 | 10:35 AM
Turbobink's Avatar
I have not used them ... yet.
And yes, they are a universal item and I've heard pretty good things
Old Jun 18, 2019 | 08:38 AM
Thanks for the info. I'm going to give it a try
bassmann
Jun 24, 2011 04:54 AM
caseymaxima
Jul 29, 2010 08:50 PM
NABU6
Oct 21, 2009 06:17 PM
NissanSE98
May 9, 2008 06:44 AM
domlcardio
Jul 31, 2005 10:46 AM
