!995 Nissan Maxima oil leak fix with at 205?
Old Jun 26, 2019 | 11:51 AM
mark217's Avatar
So I recently purchased a 1995 Nissan Maxima and it leaks oil in multiple places. It leaks from the bottom and also valve cover gasket. I'm not too concern about the valve cover gasket as most of the oil leaks from the bottom. I notice it leaks a few drops everyday. Also my power steering fluid is slightly low which makes me believe the pump has a leak. My question is would At 205 help mitigate these leaks? Also are there any other ways to mitigate these leaks without replacing parts?
Old Jun 26, 2019 | 12:08 PM
PH98I30's Avatar
Nope. AT-205 won't stop your leaks. I tried it before. Fix the valve cover leak. It will end up leaking on you exhaust and you will smell that burning oil smell. I had a PS leak also, but it wasn't the pump, just loose hose clamps. Your biggest leak is probably the upper oil pan. Just let that one go until the leak gets bad. It is a PITA to fix.
Turbobink's Avatar
Originally Posted by mark217
... My question is would At 205 help mitigate these leaks? Also are there any other ways to mitigate these leaks without replacing parts?
No.
Old Jun 26, 2019 | 02:34 PM
JvG's Avatar
JvG
Nope. No Magic Goo in a Bottle.
You need to fix the valve cover leak.
The front one is fairly easy.
The rear one can only be replaced if the upper intake manifold is removed first.
You need to know that certain parts like to fail on our engines. Several are located under that manifold.
It's best to service those while you are in there anyway.
Spark plugs, the rear fuel injectors, the egr tube likes to clog. Also check the knock sensor. Might as well clean the iacv and the throttle body. The nearly inaccessible coolant hoses should be replaced as well.
Of course you might say that I'm nuts.
My reply:
How many times would you like to remove the intake manifold.
Sorry to be the bearer of bad news.
The good news is that your car will run very well and be quite dependable afterwards
Vg30ekid
Jan 18, 2018 07:41 AM
JoshG
45
Jun 22, 2015 11:21 PM
Patm-a32
May 3, 2014 09:19 PM
leopluradonx
Apr 29, 2014 11:05 AM
