Strange P0301 Cyl 1 misfire
Old Aug 20, 2019 | 02:28 PM
PatternFlyer's Avatar
I have a question to ask.
95 SE with 240K on it.
Injectors new (remanufactured) & Coils new (Hitachi). Entire front suspension components less than a year old with quick struts. Left & Right engine mounts new. not replaced the front (passenger side) & transmission mount yet.
Plugs are new NGK.
Compression test was ok.
It keep on having misfire on cylinder 1. Not continuous.
CEL comes on. I can feel misfire (shaking).
Sometimes, car drives fine without misfire. Sometimes it misfires for a while and stop.
When in reverse it shakes a lot more.
When going on to highway while it idled smooth (no misfire), it runs good. Then, CEL pops up anywhere above 45mph blinking.
When I leave the car on idle (parked), CEL pops up sometimes after 4 or 5 minutes. sometimes after 10 to 15 minutes.
Everytime, it is P0301.
What should I look up?
Old Aug 20, 2019 | 04:43 PM
JoshG's Avatar
Make sure your injectors are spraying correctly, I had that issue back in February this year when I installed new injectors. They were stuck open. After correcting that problem, It runs smoothly after 7 months.
Old Aug 20, 2019 | 06:09 PM
Blinking CEL indicates major misfire. Per the FSM, it's not good to drive when the CEL is flashing. Replace injector #1.
I doubt it's the coilpack, but as a quick test, swap coil #1 with coil #3. Reset CEL. If code is still p0301, it's your injector, if code changes to p0303, it's your coilpack.
Old Aug 21, 2019 | 03:39 PM
JoshG's Avatar
I drove with the CEL blinking for 15-25 miles or so after the new injectors were in. Not a fun experience at all. Haha. Even though it's pretty bad to drive it with it blinking, Do no more than 50-75 miles with that... lol.
JoshG
30
Mar 13, 2019 08:39 AM
MAXIMARK
Jan 21, 2014 07:20 AM
MikesChevelle
Mar 5, 2012 10:45 PM
sachmo
Sep 19, 2006 10:20 AM
JoeB
Jul 24, 2005 07:30 AM
