skidded to avoid raccoon now high idle
OK so swapped out IACV and it at first had a bit lower of an idle, I turned the adj screw all the way in and it still idles around 800rpm even with the screww all way in, and when I stop the car and put it into neutral it stalls bad and dies, so might go back to the original IACV at least it wouldn't stall with that one, but the idle is still going to be around 900 rpm. Anyone have any more idea?
The brown TPS connector disconnect trick, I'll try this. If it's the IACV after all then by unplugging it should have little to no effect, If it has a big effect then the IACV is still ok.
Vacuum leak might be ruled out since in my experience they always have unstable behavior, this is pretty straight solid 900rpm idle, no rpm needle fluctuation.
Grey00lustre
Dec 4, 2002 03:18 PM
asianpr3082
Oct 24, 2001 08:31 PM
