Clutch Slave Cylinder Travel
Old Jun 14, 2020 | 12:13 PM
Lancep50's Avatar
Trying to rule out Clutch Master/Slave issue and determine if pressure plate has failed. Does the video of the slave cylinder seem normal when engaging the clutch?.
Old Jun 14, 2020 | 02:08 PM
JvG's Avatar
JvG
That does appear to be normal travel.
Which symptoms of clutch problems ate you having?
Old Jun 14, 2020 | 02:57 PM
Lancep50's Avatar
Clutch doesn’t engage and can’t shift. Happened quick. Maybe 4 stoplights until complete failure. Suspect pressure plate failure.
Old Jun 14, 2020 | 05:47 PM
JvG's Avatar
JvG
Was the clutch slipping before this happened?
Old Jun 15, 2020 | 06:23 AM
Lancep50's Avatar
Not at all; maybe a day or two before the petal felt a little stiff, hardly enough to notice. Definitely not enough to indicate impending failure.
Old Jun 15, 2020 | 10:32 AM
JvG's Avatar
JvG
Seems like the hydraulic portion of the clutch works just fine.
So I'd say you nedd to replace the clutch.
There are several threads in this forum which have replacement instructions. They are accessible by a Google search.
You tube should have instructions as well.
2maxguy
Feb 18, 2009 09:11 AM
NISMOPower
Nov 17, 2004 09:08 AM
wrongway15
Oct 4, 2003 11:11 AM
