Engine Firing order
Old Aug 18, 2020 | 05:40 PM
islanddean's Avatar
Engine Firing order
Hey guys
I have a 95 Maxima with the 6 cyl engine. Hoping someone can tell me what the firing order is. I got the po306 error code. Thanks.
Old Aug 18, 2020 | 06:38 PM
Originally Posted by islanddean
Hey guys
If you are standing in front of your car with the hood open, the number 6 cylinder (P0306) is the one closest to air snorkel.
Cylinders:
1 3 5
2 4 6
Old Aug 18, 2020 | 06:49 PM
islanddean's Avatar
Thank you!
Old Aug 20, 2020 | 03:41 AM
islanddean's Avatar
Coil packs
I’m NOT A MECHANIC! As a matter of fact...I’m an insult to the word but I do like to fix things myself if possible. My problem Is limited experience and limited knowledge.
two days ago I got the po306 error code so I pulled the spark plug on #6 and it looked like fine so I swapped out the coil pack with an extra one i had I started the engine and it sputtered a little but after driving it a mile or so it seemed to smooth out.
well...the check engine light came back on with the po306 code again. I rechecked the connections and they all looked fine so now I’m at a loss.
here’s my question. Are the real expensive coil packs at the Nissan dealership any different than the coil packs you can get from EBay or Amazon?
Old Aug 20, 2020 | 08:04 AM
rollcage's Avatar
you would want to go with an OEM nissan coil or go a hitachi replacement. there’s been members that have experienced issues with other replacements not being in spec with resistances. I would suggest you get either one, the hitachi is about $50 on amazon.
Old Aug 20, 2020 | 09:20 AM
Clear the CEL. Then swap coils 4 and 6 and see if the problem/CEL moves to cylinder 4 when the CEL returns. If so, you know the coilpack is bad. Replace. If the code is still on cylinder 6 after the swap, then it's likely your fuel injector causing the issues.
BullyBalla
May 31, 2004 09:13 AM
MAXIN
Oct 19, 2002 03:49 PM
