Drivers Side axle popped ou
Old Jul 25, 2020 | 01:21 PM
wdornbach's Avatar
99 max GXE 5speed, 250k
I put new axles on when I did a clutch job about 7 months / 8,000 miles ago. Installed new axle seals too. Today I noticed a puddle under the trans. Upon closer exam I noticed the axle is popped out about 1/2" so. The seal is still in place, but the axle is out just enough for the seal to be off axle so oil is leaking by.
Has anyone ever seen this happen? I made sure the spring ring was on there (drivers side axle only) before I popped it in. And yea, i took a little force to pop in, Not tremendous, but I felt it pop in good.
I'll take it apart tomorrow and see what's going on. I wouldn't expect this to just pop out for no reason. Any thoughts or suggestions? Wondering if maybe that spring ring broke.
Old Jul 25, 2020 | 11:54 PM
User1's Avatar
That's not popped out. You just have a leaky seal.
Old Jul 26, 2020 | 06:27 AM
wdornbach's Avatar
Yea, I think you're right. I took it apart last evening, the spring ring is fine. Although the axle moved in and out a little bit, it was not popped out.
Regardless, I don't quite understand why the seal suddenly went bad to the point where it was leaking badly / causing a puddle while the car was parked
I'll replace the seal and see how it goes.
Old Jul 26, 2020 | 11:03 AM
User1's Avatar
Other than the wrong seal being installed, it's hard to say without being there to see it myself. Left and right seals are not the same, and I once made the mistake of installing two left seals and had the same exact problem! My fault, live and learn!
Old Jul 26, 2020 | 02:58 PM
Zerodrag's Avatar
On my 97 5 speed, the carrier bearing was worn causing play in the shaft and leakage. Hopefully you are not experiencing that.
Old Jul 26, 2020 | 03:00 PM
User1's Avatar
His is driver side
Old Jul 27, 2020 | 01:04 PM
wdornbach's Avatar
Ok Zerodrag, what do you mean when you say "causing play in the shaft"? Did the worn carrier bearing cause the axle shaft to move in and out of the differential / case too much? Thus touching the seal? Or did the worn carrier bearing cause side to side play? Read on:
Ok Solved one mystery, but another mystery remains. I figured out why it suddenly started leaking so rapidly. It's because that metal collar shield on the axle shaft was touching the seal face and wore an actual hole in the seal face. (you know, that ring shield thing on the end of the CV axle that covers the seal to keep dirt and grime away).
So, the question is, when I installed the seal 6 months ago, did I not seat it in far enough? OR is the axle moving in and out too much causing that shield thing to touch the seal?
Pics below. You can see in the first pic taken of the back of the seal, the small pinhole. I'm holding the seal over a flashlight so you can see the light shine through the pinhole.
Pic below shows the wear on the face of the seal from the axle shield thing touching it. (old seal on left. Red arrow point to area where the pinhole is. Seal on Right is new seal for comparison.
Old Jul 27, 2020 | 01:06 PM
wdornbach's Avatar
His is driver side
See my post above. Could my axle be moving in and out of the differential too much?
Old Jul 27, 2020 | 01:59 PM
Zerodrag's Avatar
I believe carrier bearing issues cause excessive side-to-side movement, but not 100% sure on this.
https://maxima.org/forums/4th-genera...r-bearing.html
Old Jul 27, 2020 | 02:27 PM
wdornbach's Avatar
Ok, so my theory is I didnt install the seal deep enough. So I did a mock up. I installed the axle, popped it in (I heard the snap ring click). Then I moved the axle in and out to see how much it moves. I'd say about 3/16" overall in and out.
Here is a link to a youtube vid, shows the in and out play: (without the seal installed)
So I'm going to install the new seal, and drive it deeper than the previous seal, but not too deep. (My girlfriend would certainly be disappointed haha )
I'll report my findings after test driving the car for a while.
Old Jul 27, 2020 | 03:02 PM
User1's Avatar
I don't recall how much in and out movement mine had. Yours looks excessive, but I could be wrong. Drive the seal in a little deeper and I think you'll be good to go.
Old Jul 31, 2020 | 05:38 AM
wdornbach's Avatar
Update: So far so good. I installed that seal about .171 (11/64") deeper into the bore hole. I had originally (back in dec 2019 ) installed it flush with the bore face. Too close to the axle shaft shield in my case.
Caveat: The transaxle axle shaft bore hole does not have a bottom out limit stop like most oil seal bores have. If not careful you could easily drive that seal down until it touches the carrier bearing. So I had to be careful not only to get the depth correct, but make sure it was going in straight/square. It took a little finesse and I had to use the depth gauge on my vernier caliper.
I put about 1000 miles on it so far since installing that new seal. NO leaks.
Old Aug 23, 2020 | 01:54 PM
98maxBK's Avatar
Good job. I agree with your assessment that the seal wasn’t in quite enough. I did one on the drivers side and it leaked a bit initially. Turned out it walked out a little like yours. I seated it further in and it’s been good since then. My axle also has a tiny bit of side to side play, but I don’t think that was the problem just the initial installation.
Old Aug 23, 2020 | 04:21 PM
wdornbach's Avatar
Update: I've put another 4000 miles on the car since my last update, including a long highway drive trip to Florida (2000 miles round trip). No problems so far. Seal is holding up just fine.
fwiw: Got about 27 mpg / 400 miles per tankful on the highway. Gotta love it, only had to stop twice for fuel each way on my trip to Florida. AC worked like a champ too. Florida is freaking hot in the summer! This is the only car I've had in which I can say the AC can blow to the point of being too cold, even in the extreme summer heat of Florida.
Old Aug 23, 2020 | 04:39 PM
User1's Avatar
You drove all the way to Florida and didn't stop by to say hi? See if I ever offer help to you again!
Old Aug 23, 2020 | 04:42 PM
User1's Avatar
Solid work, bro. The AC system in these cars can hang meat if dialed in properly (I often freeze my food in my car because I can't afford my electric bill).
The axle stuff is commonsense, and you nailed it. Congrats, and add another point to your man card. You are the ****!
Old Aug 23, 2020 | 05:28 PM
wdornbach's Avatar
What part of Florida are you in? Didnt know since your signature doesnt mention location and my esp psychic mindreading isnt working so well today.
My family is in the Ormond area near Daytona. I'll hit you up next time I travel down there.
Old Aug 23, 2020 | 05:30 PM
wdornbach's Avatar
Solid work, bro.
lol thanks.
blkmax1
Nov 20, 2015 09:19 PM
Maxx6spd
May 9, 2014 11:38 PM
modenaf1
Jul 30, 2008 12:32 AM
heynow
18
Aug 27, 2007 07:02 AM
iansw
Apr 28, 2003 07:18 PM
