Engine code P1320 and P0300
Originally Posted by BullyBalla
not my car but a fellow maxima owner: "Today i put new spark plugs, new coil, and new fuel injectors, but i'm still having misfire, do you guys know what is the problem?" it's a 1998 SE
Originally Posted by nick778
Presuming you are saying all the coils, injectors and plugs have been replaced I'd test the crankshaft and camshaft position sensors.
thanks to my fellow maxima to post this up!!! well i replace all the injectors, coils, and new spark plugs. my car still miss fire, it throwing engine code 1320 and 0300, 1320 is Ignition Signal Circuit, and 0300 is random misfire. will the crankshaft and camshart postion sensors helps if i change it? how do you check the crankshaft and the camshaft sensor?
Originally Posted by vitec
Please help!!!!
![ThumbsUp](https://maxima.org/forums/images/smilies/thumbsup.gif)
![Newbie](https://maxima.org/forums/images/smilies/newbie.gif)
i bet u anything that your car is backfiring from your intake when u flood your gas pedal. im 99% sure that u did not use the original spark plugs, if im correct then thats what u need to replace.
Again, I am presuming you replaced everything you said you did with Nissan OEM parts (i.e., plugs and coils). The camshaft and crankshaft sensors should throw theri own codes if bad but may not if intermittent. Also, there is the possibility of your electrical harnass having a short in it and it can be tested. You cheapest assistance in testing these is to purchase a Haynes serivce manual for your Max at i.e., AutoZone for $14 and go from there.
i got the book, but i'm still having the same problem i can't figure out what is wrong. how you check the wireharness? you mean the plug? well i use OEM coil, and OEM injector but the spark plug is from auto zone NGK the regular one. but i also put back my oem plug it still missed fire. some reason there are power to the plug but nothing happen. car run like ****. if there is power to the plug? do you think there might not be ground? i'm not sure because i just brought this car like this.
derekinthez
11-13-2022 04:00 PM
