Stripped left rear brake line nut to brake hose.
Old Nov 29, 2020 | 02:36 PM
KP11520's Avatar
Yes I used a six sided 10mm flare nut wrench, then vise grip pliers. Not budging and the nut is entirely rounded.
Nissan discontinued the 46285-1L000 left rear steel brake line.
Both rear calipers are frozen despite being replaced with Centric rebuilts 4 or 5 years ago. Also want to change the hose with the new Goodridge SS hose since the other 3 are all now done!
NOW WHAT?
Anybody get tortured like this and how did you solve it?
Salt is for tequila shots.... Not to rot our cars!
Old Nov 29, 2020 | 07:05 PM
vqmaxman's Avatar
Nissan should have the nut even though it was discontinued. Nissan has classic car parts but the maxima is sadly not a classic oddly as Nissan would not care for the flagship car that help put Nissan on the map. The other option is you can call Nissan consumers and tell them this is a critical oem part that you need and it`s discontinued. The other option would be the junk yard or the home depot and some other home approvements store for a brake line nut.
Old Nov 29, 2020 | 07:39 PM
KP11520's Avatar
Thanks!
I took a Mapp gas torch to it and was able to get it to turn finally after heating the threaded brake line end. Cleaned the threads on the compression fitting and used anti seize compound on the threads of the SS hose. Was a PITA to get threaded finally and had to tighten it with Needle nosed vise grips. Not Leaking thankfully!
Nothing like working at night when things go wrong. (Always with my Maxima.)
Old Nov 30, 2020 | 06:26 PM
vqmaxman's Avatar
glad that you got it off. I was gonna mentioned the blow torch method but, I knew you were gonna get it off.
Old Dec 1, 2020 | 03:46 AM
Turbobink's Avatar
It appears as though most everyone else from your state is relocating to my state Keith ... so what’s your problem?
Down here cars don’t experience much rust but they do get “jacked” fairly frequently.
Old Dec 2, 2020 | 02:59 PM
KP11520's Avatar
The problem IS your first sentence.... Errrrrrr
Who the hell would want to be with New Yorkers when it's time to get away from them.
That's like rubbing SALT into my wounds! LOL And back to where I started!
edwardh1
Jan 29, 2017 07:41 AM
Peace1967
Oct 11, 2015 02:35 AM
Curt Deiner
Sep 10, 2008 03:19 PM
spirilis
Oct 24, 2003 11:27 PM
