Po600 code - comm link
Old Nov 29, 2020 | 05:41 PM
Jenr's Avatar
Hi,I'm trying to resolve a P0600 code on my 98 maxima. The EC Manual say to check for continuity between terminals on ECM and TCM. The terminal pairs are (ECM - TCM) 65-47, 66-38, 73-10, 74-11 and 77-12. I'm not getting continuity between and of the pairs. I have my battery disconnected although the EC Manual is asking to turn the ignition OFF only. I find it strange that continuity doesn't exist between any of the terminal pairs. Am I doing something wrong. Any help would be appreciated. Thanks in advance.
Old Dec 10, 2020 | 11:32 AM
maxfever1987's Avatar
It might be your speedometer cluster, first try and clean the connection on your speed sensor, I have seen numerous 95 96 maxima have this code and the cluster wound up being the issue, if you have a spare try this before changing the tcm or ecu
Old Dec 10, 2020 | 09:58 PM
vqmaxman's Avatar
The code stating that its a break or a short in that line to ecu-tcm.
Old Dec 21, 2020 | 10:26 AM
Jenr's Avatar
Thanks for the feedback. MaxFever1987- I haven't been back at it yet but I will try the cluster thing.
vqmaxman - I just find it strange that there were no results in any of the wires i checked for continuity. Which means that the entire harness section between ECM and TCM is cut right through. Don't you think that's unlikely?
Old Dec 21, 2020 | 07:49 PM
vqmaxman's Avatar
The continuity reading should read with 0.00 reading means that you have no shorts and you have good continuity. The short or bad continuity would read a high 1.00 or more.
Steven Orozco
Sep 12, 2015 10:41 PM
Drakes
Feb 22, 2011 09:18 PM
Magikone69
Apr 27, 2004 08:38 AM
Keven97SE
Sep 5, 2000 01:07 PM
