Heater and AC problems
Old Jan 20, 2021 | 06:43 PM
Maximus10's Avatar
got a 98 Maxi, and my heater and ac doesn't work ,my control is digital but if I go all the way to cold still only heat is coming out
does any friend here had this same prob or really anyone who can guide me in this fix ?
please and thank you Maxi Community !
Old Jan 22, 2021 | 09:27 AM
maxprivate's Avatar
Black Lion
heat and cooling?
check and see if your compressor is coming on. could be a fuse, or faulty compressor. maybe thermostat issue as well. Theres a ton of info around here if you search around on how to diagnose it.
Old Jan 22, 2021 | 04:04 PM
KP11520's Avatar
Most likely a Heater/AC Blend door actuator.
The FSM has a procedure to use the climate control panel to diagnose what has gone bad. Download the FSM from here and research the proceedure and you'll get your exact answer. Then order an OEM Nissan part to replace it. Then you'll be good for another 20+ years.
Old Jan 25, 2021 | 04:15 PM
Maximus10's Avatar
thank you to everyone !
I downloaded the 1998 FSM , in the HA section shows all parts , but yes according to my issue the problem is on the door that mix from the cooling unit and the heater unit, I notice there's a tiny arm when I moved it manually works but cant regulate enough . is cold or hot hot.
I'm kind of scared because it seems to me that the whole dash needs to be removed but I hope to be wrong
Old Jan 25, 2021 | 06:05 PM
KP11520's Avatar
Coma at it from the bottom by removing the ECU and anything else blocking access. The actuator motor is shot.
Old Feb 5, 2021 | 07:45 PM
Maximus10's Avatar
well doing some research I found this pic
and this exactly what I found as failed , does anyone knows where to start here
thank you ...
Cap916City
Mar 20, 2012 09:02 AM
Sinister-13
May 29, 2011 05:43 PM
skillton
Jul 5, 2006 07:53 PM
ZeRo MaX
Jun 22, 2002 04:06 PM
