98 max shift lever
Old Jan 26, 2021 | 07:41 AM
stoogey95's Avatar
98 max shift lever
Hello, I have a 98 max w/ auto trans. My shifting lever works fine and engages into all gears properly, but my problem is my shifter wont lock into gear ( R, N, D, 2, 1 ) I can shift w/o pushing button in and worry car may shift from drive - neutral while driving accidentally...Has anyone else had this problem and does anyone know what problem could be? Any help greatly appreciated, thanks
Old Jan 26, 2021 | 03:59 PM
battlestylespl's Avatar
The neutral safety switch could be wearing out, i would start there. Its on the front of the trans.
Old Jan 27, 2021 | 04:43 AM
stoogey95's Avatar
thank you for the advice ! I did put brand new safety neutral switch in. I will have to get an extra set of eyes so I can check out what's going on under there while someone is shifting gear selector.
Old Jan 27, 2021 | 03:38 PM
Reality sucks's Avatar
Go out to Your car.. Lift up and remove Your Shifter Bezel/trim, To the right of the shifter look down, you'll see a threaded Rod, Roughly 4mm by 4 inches or so. It should be locked into the Sheathing ahead of it. They usually pull out and fall downward. You can attempt to push it back into the cable and somehow lock it into place.But the lock tabs usually break thus causing this problem. Its called a Shift lock cable.
ladyvolsrule
Jan 1, 2020 10:38 AM
ladyvolsrule
Nov 23, 2019 05:01 PM
toucansma
Jan 21, 2005 05:50 PM
Smokey
Feb 14, 2004 12:08 PM
driver824
Aug 21, 2002 02:37 PM
