Pink door wire
Old Feb 7, 2002 | 04:08 PM
mbb6's Avatar
Pink door wire
Need to know what the pink wire is that goes into the passenger side door switch. Thanks Cannot find it in my 96 manual, please check 95 or 97-99
Old Feb 7, 2002 | 05:02 PM
Chunger's Avatar
My other car is a Hybrid
Re: Pink door wire
I'm not looking at a manual but... if there are two wires... one is the source and the other a 'trigger' when the door is opened... i would use a different wire for an alarm trigger...
alarm for 4th Gen?
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|wht/red or wht/pur |+ |ignition harness |
| STARTER|blk/yel or blk/wht |+ |ignition harness |
| SECOND STARTER|grn/blk or red/blu |+ |ignition harness |
| IGNITION|blk/wht or blk/red |+ |ignition harness |
| SECOND IGNITION|red/yel or red |+ |ignition harness |
| ACCESSORY|blue or wht/blk |+ |ignition harness |
| POWER LOCK|lt. green/red |- |in drivers door at switch |
| POWER UNLOCK|green/yellow *1 |- |in drivers door at switch |
| LOCK MOTOR|brown/white | |in drivers door at switch |
| UNLOCK MOTOR|brown | |in drivers door at switch |
| DISARM DEFEAT|brown | |in passenger door at switch |
| PARKING LIGHTS +|red/green | |steering column |
| HEADLIGHTS|gry/yel(L)blu/blk(R)|+ |steering column |
| DOOR TRIGGER|red/white |- |low in drivers kick |
| TRUNK/HATCH PIN|purple/yellow |- |drivers kick or BCM *2 |
| HOOD PIN|yellow/black |- |BCM *2 |
|TRNK/HTCH RELEASE|purple/yellow |- |low drivers kick *3 |
| FCTRY ALARM ARM|arms w/ lock | | |
|FCTRY ALRM DISARM|disarms w/ unlock | | |
| DISARM NO UNLOCK|*4 | | |
| TACHOMETER|white/green | |ECM *5 |
| BRAKE WIRE|red/green |+ |at brake switch |
| HORN TRIGGER|green/white |- | |
| WIPERS|lt. green/red |- |steering column |
| LF WINDOW UP/DN|blu/red - blu/blk |A |in LF door at switch |
| RF WINDOW UP/DN|blu/red - blu/blk |A |in RF door at switch |
| LR WINDOW UP/DN|blu/red - blu/blk |A |in LR door at switch |
| RR WINDOW UP/DN|blu/red - blu/blk |A |in RR door at switch |
Notes:
Note: The ignition harness wires change color at a plug. The above listed colors show both sides of the plug.
*1 Requires a double pulse.
*2 The BCM (body control module) is located just below the radio.
*3 Must use a relay to interface with this circuit.
*4 A single negative pulse to the unlock wire will disarm without unlocking.
*5 The ECM is located in the front of the center console on the transmission hump. The wiring is easily reached by removing the small black panel just to the front of the center console on the passenger side. the wire is in the middle row, 7th one in from the left.
Old Feb 7, 2002 | 08:14 PM
StaindMaxima's Avatar
Re: Re: Pink door wire
alarm for 4th Gen?
Notes:
Hey that looks like a DEI tech sheet.....am I right?
Old Feb 7, 2002 | 11:39 PM
Chunger's Avatar
Re: Re: Re: Pink door wire
I'll never tell...
Old Feb 8, 2002 | 07:32 AM
mbb6's Avatar
passenger side doors have a clip that has like 8 wires on the bottom and a 2 to 3 wires on top. The bottom wires are the brown/ brwm/wht/ blue and all such but the top two have a different function, maybe power maybe something else, i have a pink wire going into my door switch that is not listed in the manual. weird huh, can anyone see if the I30 has this in it's door, i may have different wiring from a previous owner.
Derrick2k2SE
Nov 19, 2015 10:14 PM
ef9
Sep 29, 2015 11:29 PM
lkiller123
Sep 21, 2015 03:00 AM
ajahearn
Sep 19, 2015 03:03 PM
