Wiper linkage replacement frustration
So I broke the wiper linkage/wiper transmission a week or so ago, and purchased a new one from Rockauto (Dorman) because there are essentially no 4th gens in the local junkyards anymore as they've all been crushed due to rust around here.
The issue is the connector between the linkage and the motor.
The connector that came with the linkage has a hole that is too big for the shaft on the motor. The old connector has a smaller hole with ridges that match a spline on the motor shaft. The new connector's hole is so big it slides right past the spline.
So I thought about using the old connector from the old linkage but its ball is too big for the new linkage socket (very hard to turn once connected, even when lubed).
Not sure where to go from here.
Thoughts?
Thoughts?
Sadly though once it was all together I tried it out and it seems the original stress of the linkage breaking damaged the motor gearing because although it works there is bad grinding/thumping from within the motor housing
So now I'm bidding on eBay used motors...
I appreciate your offer.
Just an update which might be helpful for anyone else doing this repair on an earlier 4th gen model. Apparently the wiper hardware was changed at some point. As I mentioned above the motor linkage that came with the wiper transmission had way too big of a hole to fit my existing motor.
Well once I got a new motor the old linkage that I had modified to fit the new transmission now wouldn't fit the new motor because the new motor shaft was far bigger so the motor linkage that came with the new wiper transmission now fit the new motor, but! Of course the washer and nut that came off the old motor won't fit on the shaft, so off to home depot to find replacements. Super annoying.
1996 model year built May 1995.
KeithLHawkins
04-09-2002 10:44 PM
