Vaccum line location
Old Jun 18, 2022 | 11:59 AM
rroderiques77's Avatar
Demodded and Forgotten
I have a 99 Maxima and replaced my rear valve cover and now can't find where this vaccum line connects to. Closest place I can think of is the snorkel but i don't see a port anywhere other than that sealed tab. Also setting a P1105 Map/Baro code which started after repair. I'm thinking loss of vaccum assist somewhere from that disconnected line.
Old Jun 18, 2022 | 12:13 PM
JvG's Avatar
JvG
Keep in mind that one rubber hose like that is a transmission vent tube.
Old Aug 22, 2022 | 03:14 AM
mabsarer22's Avatar
Not sure if that engine diagram is exactly yours but it should be close. Do you have any vacuum lines present at all? If so it should be easy to replace those but if you’re missing some the diagram will help you find the fittings that are missing lines.
Old Aug 18, 2024 | 04:01 PM
mabsarer22's Avatar
Originally Posted by mabsarer22
Not sure if that engine diagram is exactly yours but it should be close. Do you have any vacuum lines present at all? If so it should be easy to replace those but if you’re missing some the diagram will help you find the fittings that are missing lin .
It’ll take some time digging around but just use a flashlight and scour the engine bay, you’ll find them
1999i30t
Sep 5, 2020 09:52 AM
Ephraim
Jul 10, 2007 08:03 AM
mofoaka
May 31, 2005 06:11 AM
