ECTS and Knock Sensor codes, engine stalled, starting issues
Old Oct 10, 2022 | 02:16 AM
RITE's Avatar
Engine has been having some minor rough idle on and off for many months now. Today the owner of the car had a difficult start, and less then a mile from home the engine started dying and stalled. It did not want to start back up again, but after sitting a couple mins, it did and was able to drive home. Yellow CEL appeared, I checked codes and its ECTS and knock sensor. I looked up a bit on this site and it seems the ECTS prolly went bad and is the cause of this issue.
I bought one from Autozone for $23 and planning on installing it, but would like some guidance about how to do it. I seen videos and advice to just install it without any sealant (such as teflon), but Chiltons manual says to use conductive sealant and not teflon tape. Can I just install it without any sealant?
Also about removing it, can I spray WD-40 on it if it does not want to loosen, and then gently tap wrench with hammer? I dunno much about car repair, but I do change oil and brake pads, and rear strut assembly (easy jobs).
Also what is the torque spec on the ECTS if anyone knows? I don't want to strip the thread.
Old Oct 10, 2022 | 03:21 AM
Turbobink's Avatar
Before you do any replacing, make sure the harness connection isn’t the issue.
- Clear the DTC.
- Unplug and replug the sensor’s connector until it clicks.
- Do the unplug and replug 3 times.
- Run the car and look for the DTC.
If the sensor is confirmed bad and is replaced, try removing it with engine warmed. This may free it up a bit.
Also, I’ve never needed any sealant.
Be careful when removing. The sensor housing is plastic … and likely old, heat weathered and brittle plastic … and it’ll crumble.
Old Oct 10, 2022 | 06:24 PM
RITE's Avatar
- Clear the DTC.
Thanks for your input. I did what you said about clearing CEL and plugging/unplugging connector a few times. The ECTS code is gone, only knock sensor code remains, but CEL is off. I drove about 2 miles around town and idle seemed smoother, maybe even normal I dunno, but maybe it's too early to tell.
Do you think I should disconnect the battery and clean the connectors of ECTS with electrical contact cleaner? Maybe that will improve connection? Also what do you think about the knock sensor code that remains, should I clean it's connectors first too before buying a new one?
Old Oct 10, 2022 | 09:04 PM
JvG's Avatar
JvG
No need to buy a knock sensor.
It is a ride along code. It pops up when ever an other code does
cleaning the ects contacts might help if you live in an area where road salt is commonly used.
Old Oct 10, 2022 | 10:11 PM
KP11520's Avatar
I don't know why so many refuse to put the year Maxima in the narrative. A Knock Sensor Replacement in a 1999 Maxima is way different than previous years.
Everything off the top of the engine, all the way down to, and including including the lower intake manifold. And if going that deep and not replacing all that can be tired is a HUGE mistake.
If details are too much work. DON'T fix cars. Assuming anything is just ........Lucky for you, JvG saved you from thinking you can handle this.
I always clean connector plugs when reattaching everything. Probably not necessary if never left unplugged for any period of time. But overkill usually won't hurt anything and sometimes helps.
I doubt the ECTS is your only problem, but you won't know until it's remedied.
Old Oct 11, 2022 | 01:21 AM
RITE's Avatar
The car has been in my signature all along.
Old Oct 11, 2022 | 09:52 AM
KP11520's Avatar
I don't know why I never noticed it ever before! Maybe because I only log in when I post, and signatures are only seen by those that are logged in. Another reason to put the details in the POST when seeking help!
Some of the later 98s have the same intake as the 99s. Painful job to replace the knock sensor if so, and needed. .
Old Oct 12, 2022 | 04:13 AM
Turbobink's Avatar
I agree with Jv … going an extra step to make sure everything is communicating properly is never a bad thing.
Also, battery disconnection and fully clearing stored DTCs certainly won’t hurt.
Old Oct 12, 2022 | 10:02 AM
Prophecy99's Avatar
"ride along code", nice, i also have heard it called "piggy back code",
i have had the knock senor code almost 9 out of 10 times pop up when other codes are there, and each time when I address the other main problem code the knock sensor code goes away.
i actually had the knock sensor code pop up the first time all by itself the other day 1 week after inspection, i erased it and knock on wood it didn't come back. but i don't remember ever seeing it pop up alone like that.
jkslaughter@hot
Jul 2, 2007 03:53 PM
Lovejoy
Nov 29, 2004 05:29 PM
johnnyrock
Sep 27, 2004 01:46 PM
Fish254
Oct 3, 2003 09:28 PM
myamin
Aug 23, 2002 12:47 PM
