No heat right after getting the A/C fixed?
Old Mar 15, 2023 | 10:00 PM
bojanglesdude78's Avatar
I have a 99 SE-L and recently had to get the radiator fans replaced, as one wasn't spinning and it was causing the air conditioning to blow hot air. After I got it back from the dealership, the A/C works amazing but now the car only blows cold air, even when I have the thermostat set to 85 F or I turn the front defrost on. The engine does not appear to be overheating when I drive, and the coolant is definitely filled up.
What could be causing this problem? About a day before the radiator fan repair, the car stopped blowing hot air and just wasn't blowing any air at all, so I don't know if the repair is to blame. Any help is appreciated!!
Old Mar 15, 2023 | 10:26 PM
KP11520's Avatar
Have you downloaded the Field Service Manual yet posted here in many places?
There's a sequence of button pushes using your HVAC control panel that will diagnose what isn't working properly. This way there will be no guesswork and you can replace what is broken the first time.
Old Mar 16, 2023 | 11:49 AM
chrome91's Avatar
Can you see/hear the compressor clutch engage when you idle it with AC on?
Old Mar 16, 2023 | 05:19 PM
98maxBK's Avatar
Possible your blend door/ air mix door actuator went. Stick your head under the dash from the passenger side and look toward the center behind the computer. Pop the black plastic cover off first. There is a small black box with a white arm atop that rotates and opens the blend door to let more/ less hot or cold air in. If you change the temp with your left hand while your looking at it and it doesn’t move that’s your problem. I did one recently however mine was stuck on hot no matter what the setting.
Old Mar 17, 2023 | 03:33 AM
Turbobink's Avatar
Since you’ve already been to the dealership to have a cooling fan replaced that resulted in another issue, why not return to the dealership, explain the issue that that repair apparently has caused and raise a little hell?
Old Mar 17, 2023 | 09:12 AM
KP11520's Avatar
Read: "About a day before......" part! That leaves a big blurry line. Better off just running the self diagnosis, that will most likely confirm a blend door actuator failure.
Get 'em now before they go extinct!
Pnjboyzz
Dec 20, 2015 11:29 PM
rellrealist
27
Apr 3, 2015 12:43 PM
maximaman1313
27
Apr 2, 2009 12:50 PM
serenity97
21
Jan 26, 2009 07:07 AM
tarun900
Jul 16, 2008 03:02 PM
