Maxima starts fine idles fine but if I give it gas or put it into drive it dies
Old May 1, 2023 | 04:29 AM
bleachersrock's Avatar
I have a 1998 Nissan Maxima starts fine idles fine but if I give it gas or put it into drive it dies there's also a tick/ clicking noise coming from the pulley side of the motor but it's been doing that for about 6 to 9 months I was driving regularly and other than the tick/ clicking noise I didn't really have any issues except very quiet backfire occasionally oh yeah I put a new (MAS), and fuel pressure regulator and cleaned the throttle body and (IAC) valve recently and the plugs are only about 4 months old. If anyone can help I'd really appreciate it thanks
Old May 1, 2023 | 08:21 AM
I suspect it's your MAF. Did you install OEM or aftermarket?
Old May 1, 2023 | 09:57 AM
Aftermarket
Old May 1, 2023 | 02:23 PM
Turbobink's Avatar
I’d also suggest replacement of the cam position sensor and both crank position sensors.
Old May 1, 2023 | 11:01 PM
how long have you been runnin' with an aftermarket MAF? And did it run perfectly fine for a bit?
Old May 2, 2023 | 02:36 AM
It was around the middle of March and yeah it ran great until April 21 I drove it to work and home and as far as I know there was no problems and Monday when I was trying leave for work it started just fine it was idling normal I put into drive and it died I started it up again it did the same thing started it again gave it some gas and it died again then I called for a ride to work
Violator
Aug 14, 2018 06:14 PM
cjandura
Jan 21, 2012 12:33 PM
Josh_GlenBurnie
Nov 22, 2004 11:41 AM
Vaudeville Villain
Jun 14, 2004 07:06 AM
