Changed Oils after recent posts...
Old Feb 8, 2002 | 03:39 PM
PhantomMenace's Avatar
After reading the recent posts about oils, and reading the stat sheets, I did an expensive oil change! But I'm sure it'll be worth it in the end.
I did a tranny flush, and put in AMSOil Synth, and Engine Oil change to 0W 30 synth.
The shifts feel alot smoother already and I'm very pleased. However, I had this done at my Nissan dealer and they put the generic oil filter, should I upgrade this at all??
-Phantom
Old Feb 8, 2002 | 03:53 PM
sbslacker's Avatar
Re: Changed Oils after recent posts...
-Phantom
The Nissan OEM filter is a good quality filter, you should be fine.
Old Feb 8, 2002 | 05:03 PM
SuDZ's Avatar
Re: Re: Changed Oils after recent posts...
Actually on test at sites like www.motorcate.ca it was deemed better than other aftermarket ones like fram etc.
SuDZ
Old Feb 8, 2002 | 05:12 PM
Cool, thanks guys...
Old Feb 8, 2002 | 05:22 PM
pocketrocket's Avatar
And next time, change the oil yourself. You won't have to worry about someone screwing with your car, also you get more for your money!
Old Feb 8, 2002 | 05:48 PM
I usually do change it myself and I will from now on. Just changing from regular to synth I figured I'd let them do it, and I couldn't do the tranny change myself.
-Phantom
Old Feb 9, 2002 | 12:23 AM
Steve Marsh's Avatar
replace the filter with an Amsoil one the next time around. Nissan is a good filter, but Amsoil goes the extra mile 96se auto 163,000 plus all amsoil lubricants.
Old Feb 9, 2002 | 12:55 PM
iwannabmw's Avatar
-Phantom
Steve's right, the Amsoil filter is better, but the Nissan one is also very good. Amsoil says it's okay to use the OEM one instead of theirs, the only catch is if you're going to go with extended drain intervals, they recommend that you change the Nissan filter at the manufacturer's recommended mileage, while their filter is approved for 6 months or 12,500 miles. There is absolutely nothing wrong with using the Nissan one and I wouldn't change it out until you're supposed to.
Old Feb 9, 2002 | 01:47 PM
Thanks for all the input... I'll wait the suggested time to change the filter, and put an AMSOil on after that.
-Phantom
The Wizard
24
Oct 1, 2015 08:47 PM
cruce91
Sep 20, 2015 10:23 AM
97_GXE
20
Sep 17, 2015 08:12 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
