1996 Maxima GXE Automatic - Key stuck in ignition
Old Sep 3, 2023 | 03:00 PM
1996maxgxe's Avatar
Read relevant threads, Can't seem to get an answer.
Key is stuck in ignition.
Car starts and runs fine.
When I put it in PARK, the key will NOT come out.
It seems to stop a little bit short of the last click.
Tried moving shifter all the way back and forth and up againast the PARK stop.
No luck.
Is there a switch of some kind in th eshidter that feeds into the ignition switch?
Couls that switch be bad?
Is it called the PARK POSITION SWITCH?
Internet says it is discontinued :-(
Could it be something else?
Help!
Old Sep 4, 2023 | 01:50 PM
Try slamming it into park
Old Sep 4, 2023 | 10:10 PM
KP11520's Avatar
Yes there is a cable that activates a key release connected to the shifter. It's pretty easy to disassemble enough to look at the shifter end to see what happened.
Old Sep 23, 2023 | 01:41 PM
1996maxgxe's Avatar
Tried slamming shifter back and forth. No luck.
Also noticed that Remote is not working.
This may mean that the car thinks it is NOT in PARK.
Although it starts just fine which is weird.
Do I need to dismantle the entire console to find th ecable that activates the key release?
Is there a PARK POSITION SWITCH in the 1996 automatic?
Could this be the Neutral Safety Switch or does that have different symptoms?
Thanks again!
Old Sep 24, 2023 | 10:54 AM
JvG's Avatar
JvG
Have you tried turning the steering wheel slightly while gently pulling on the key ? I mean turn it towards the right or left.
redcoat
Oct 9, 2013 10:14 PM
webjohn
Apr 6, 2008 04:05 AM
PhaZe
Dec 22, 2004 12:46 PM
smackdownGTR
19
Oct 29, 2004 11:55 PM
jason r
May 5, 2001 08:14 PM
