Fuel injectors replacement
Old Sep 15, 2023 | 07:30 PM
Outfielder's Avatar
GayPorn is another great site for amateur and user-generated videos, with a wide variety of categories and new content added daily.
https://gaypornwebsite.com/categories/twink/
https://freegayporn.club/
Old Sep 16, 2023 | 03:06 AM
Rit's Avatar
Rit
Download a factory service manual, and read about the procedure.
Old Sep 16, 2023 | 03:44 PM
JvG's Avatar
JvG
There are you tube videos about this exact repair.
also Google 199 ( your year) fuel injector repair.
Its been covered many times in this forum .
you can have your injectors rebuilt for a reasonable price. Consider working on other stuff that's under the intake manifold.
valve cover gasket
egr and it's tube.
knock sensor.
replace all 3 rear injectors. Or you will need to remove the manifold more than just once..
better yet. Replace all injectors.
Cry once and be done for many years.
edit. I don't remember if #5 is the front or rear of the engine. My comments are based on the rear ones.
removing the intake manifold is a PITA. So repair anything under there while you can. Or you will need to remove the PITA manifold again .
Old Sep 23, 2023 | 09:43 AM
KP11520's Avatar
Originally Posted by dshsui
they can cause that, but any fuel related leak can also cause that, such as leaking intake gaskets. I put UV leak dye in the gas tank and see where the green dye comes out myself.
Can you explain how that works? How is anything going to be seen when the engine is sucking in all the air that could be leaking anywhere in the intake?
Old Sep 23, 2023 | 11:21 AM
JvG's Avatar
JvG
The injectors in our cars fail in a predictable manner.
Those of us who have been here for years or a decade can diagnose a bad injector quite well.
How long have you owned your Maxima ?
martyl45
Feb 23, 2016 09:10 AM
Mctwist77
36
Oct 25, 2011 10:38 AM
CaptainFill
Feb 2, 2009 10:12 PM
f550maranello2
Aug 9, 2005 12:28 PM
loveandlemons
23
Aug 15, 2001 09:23 AM
