CYlinder Compression
Old Dec 15, 2023 | 05:18 PM
Leogane's Avatar
Question: After a piston cycles one time, the compression on that cylinder is at its peak no matter how much we keep cycling it; right? I have a 1995 Maxima, and I was getting 125psi, I let it sit for about 20 min then continued cycling, the psi eventually got to 165. Is that normal?
Old Dec 15, 2023 | 06:17 PM
JvG's Avatar
JvG
Procedure.
Open throttle all the way.
crank for 5 or 6 pulses to the meter. The compression will peak .
Write down for each cylinder and tell us what you find.
We look for a pattern. The pattern can identify a worn engine, a problem with only 1 cylinder, or blown headgasket
Tell us why you are checking compression
Old Dec 15, 2023 | 06:32 PM
Leogane's Avatar
That does not answer my question. But the answer to your question is cyl.1=125 psi cyl.2=145 cyl.3=150 cyl.4=125 cyl5=150 cyl.6= 135
Old Dec 16, 2023 | 02:25 AM
Turbobink's Avatar
nissandrvr
Apr 14, 2010 04:03 PM
Maxteca
Nov 9, 2007 01:47 AM
RiggZola
Jun 18, 2005 08:49 PM
outsider
Apr 9, 2004 05:34 AM
