Is this a bad PCV valve?
Old Aug 14, 2024 | 04:29 PM
RITE's Avatar
I changed it to an AutoZone one 4 years ago, didn't change the grommet though. Today I noticed there is oil on the exterior of the valve and a little on the hose that connects to it... oil like from vapor leaking through seals. Also I noticed there is some oil around front valve cover gasket... also like vapor leaking through. Also, I'm not totally sure, but I think today when I reached for the oil dipstick in the dark, it was popped out a bit. Also been having a very faint rough idle, usually until engine warms up... dunno if that's connected or from something else.
No CEL yet, but I read the flashing codes and it blinked 0304, which is knock sensor. I had knock sensor replaced a couple years ago.
Old Aug 15, 2024 | 12:00 PM
RiderBobo's Avatar
I can't help you. I have never had the need to replace the PCV valve on my 95SE, although it only has 124,250 miles on it.
I did have the valve cover gaskets replaced a while back because of leakage.
Old Aug 15, 2024 | 02:14 PM
Turbobink's Avatar
Originally Posted by RiderBobo
I can't help you. I have never had the need to replace the PCV valve …
Then I’m not certain why you replied …
Old Aug 15, 2024 | 02:17 PM
Turbobink's Avatar
RITE,
I’d personally recommend that you go ahead and change them both out again … the PCV (+ the grommet this time) as well as the knock sensor.
They’re both relatively inexpensive and can both be replaced using up a given Saturday or Sunday.
Old Sep 21, 2024 | 02:23 AM
Bardamu's Avatar
Hi,
I had this problem with PCV valve (bad idle, lack of power, etc.). I changed the PCV valve with second market and it improved but wasn't perfect. Ionly solved the problem completely when I put an OEM part.
PUT AN OEM PART, otherwise it will not work perfectly.
desktop
35
May 10, 2019 01:11 PM
car5car
Mar 15, 2014 05:10 AM
tucker
Oct 30, 2007 09:29 AM
zarek66
May 14, 2006 01:46 AM
