Fuel injectors won't click
Old Mar 24, 2025 | 05:43 PM
Pence's Avatar
I have a 99 Maxima. She was running fine and out of the blue she wouldn't start. I checked with a stethoscope the fuel injectors and I didn't hear them click. Then I checked power to them and I'm getting 3-4 volts. Any ideas as to why this may be happening.
Old Mar 25, 2025 | 12:33 AM
Is your security light solid red? If so, NATS got you and is preventing your Max from starting. ie no fuel
Old Mar 28, 2025 | 06:25 PM
Pence's Avatar
So it was nats, but I have a new issue l, whenever the mechanic tried programming a new key it was giving issues connection to the ECU through the obd2 port.
Is this a common issue?
Old Mar 29, 2025 | 11:00 AM
KP11520's Avatar
I don't remember if the OBDII port is the right one. Most likely it's the port on the right side of the fuse box under the dashboard, which will use a different cable and connector.
xnos
56
Sep 1, 2008 08:37 AM
Maximized Jiggs
20
Jun 18, 2004 04:54 AM
