Filling M/T ?? Where ??
Old Feb 10, 2002 | 02:04 PM
matty's Avatar
Well I opened up my hood today looking for the drain plug and the fill plug on my M/T and I cant find the fill plug on top of the Trans ?? I got the long funnel and the Redline MT-90 and im clueless
Old Feb 10, 2002 | 02:14 PM
Bags's Avatar
VG Ridah's Biatch Hoe
I think you should get a service manual but I will give you the best descripition I can. ( I have an AUTO )
Looking at the tranny case , it's on the THICKER side of the housing.
Going from the drain plug it's less then 270 degress from there.
Old Feb 10, 2002 | 03:50 PM
iwannabmw's Avatar
If you're facing the car, the fill plug is a large circular plug located on the front of the transmission facing you, a little to the right and about halfway up the case. To open it, you need a 1/2" socket extension to stick in the recess so you can turn it. It is much bigger than the drain.
Old Feb 10, 2002 | 03:51 PM
jargoone's Avatar
Re: Filling M/T ?? Where ??
I hated this too. The manual didn't even help me. Lie on your back right under the center of the car. The drain plug is on the passenger side, going in towards the driver's side. It looks like an ordinary bolt that's sort of out of place.
I really need to take a pic next time my car's up.
Old Feb 10, 2002 | 03:58 PM
Confused's Avatar
Permanent Maxima.org Resident
I believe there is a writeup on maximadriver.com
Old Feb 10, 2002 | 04:08 PM
Bags's Avatar
Thanks I was trying to help using the pics from the FSM.
SuDZ's Avatar
If you use this write up though when they show you the pictures print them out and hold them upside down.
SuDZ
Old Feb 10, 2002 | 08:24 PM
matty's Avatar
After draining it did you lower the car back down so the car is level with the ground then fill the tranny ??
05RLS2
Nov 7, 2016 05:52 PM
Fbana41
Aug 29, 2016 12:18 PM
ef9
Oct 4, 2015 08:43 AM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
