Squeaky Pedals
Old Feb 14, 2002 | 11:06 AM
AdMax98's Avatar
Squeaky Pedals
I've noticed lately that my clutch and brake pedals are starting to squeak. I tried to spray some WD-40 on the joints but they're hard to get at. Anyone have any tricks they'd like to share for fixing this problem?
Old Feb 14, 2002 | 12:48 PM
95emeraldgxe's Avatar
my break squeaks when i release it, but not when i press it down - a solution to this topic wood be nyce =)
Old Feb 14, 2002 | 12:55 PM
AdMax98's Avatar
Yeah, they both only squeak on release.
Old Feb 14, 2002 | 01:16 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
There is a "little" button/switch for each clutch and brake pedal. Actually there are two for the clutch- one for when you depress the clutch pedal and one for when its released. Lubricate the button(s) and the squeak will go away. I lubed the clutch release button and my pedal doesn't squeak anymore when i release my clutch.
Old Feb 14, 2002 | 01:21 PM
where is this button located???
Old Feb 14, 2002 | 01:29 PM
VeeQueue's Avatar
For the brake pedal it is located near the pedal's pivot point. Turn on the engine (preferable) , press the pedal down and you'll have enough clearance for your finger to press that button/switch. The button is facing towards the front of the car.
For the clutch you can clearly see the "clutch-in" button. Its a skinny black button. The "clutch released" button is facing the front, just like the brake button/switch. You'll have to depress the clutch pedal to feel the button.
Old Feb 14, 2002 | 01:36 PM
VeeQueue's Avatar
Re: Squeaky Pedals
Also, I used a silicone lube spray to lubricate the springs and the misc. pedal assembly parts. I covered my pedals with a plastic bag and lined the carpet with paper and sprayed a light mist. I had a multipurpose grease gun dispenser and it was a PITA using that to lube the recommended points. I have no problems whatsover with the silicone lube spray. It will last a lot longer than wd40. But based on what you wrote I have a feeling the cause of the squeaking are those button/switches.
EDIT: I also want to suggest that you use something other than wd40 for those switches. Use some type of grease. It will last a lot longer.
Old Feb 14, 2002 | 01:37 PM
AdMax98's Avatar
Cool, thanks alot!
ef9
Oct 4, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
