help with painting 95/96 red/clears
Old Feb 14, 2002 | 05:16 PM
paul-e's Avatar
yes i used the search button and didnt really find what i was looking for.
im gonna be using spray paint im guessing? anyone have any name brands i can get at like a pep boys or somthing? and the color?
im gonna be painting the outside so i guess im gonna use duck tape to get the perfect match. how many coats should i put on? if anyone can gimmie some tips or easier ways that would help too. thanks guys
Old Feb 14, 2002 | 07:10 PM
clee130's Avatar
It's called candy-apple red I believe ... something like that.
And people say two to three coats should be enough.
The best thing is to take it apart and paint the inside though.
Old Feb 14, 2002 | 07:18 PM
ny96max's Avatar
www.lightningmotorsports.com
they sell VANS red tail paint($30 acan), perfect match to inner tails. Look at my sig for proof. They were done about 3yrs ago and look as good as the day i bought them. David L is the king of making 95/96 tails.
BTW they are painted from the inside. Lots of guys here who have them sprayed from the outside experiance nasty fading and scratches.
So its up to you, inside or outside
Ant
Old Feb 14, 2002 | 09:13 PM
paul-e's Avatar
thx guys but im lazy and gonna do the outside.
Old Feb 14, 2002 | 11:07 PM
bmxsteve's Avatar
I did the outsides about 2 weeks ago...so I guess time hasn't had a chance to work against me yet. I bought "testors transparent candy apple red" and it looks fine. I put about 6 coats of that a 5 coats of clear coat. So far, so good.( knock on wood)
Old Feb 15, 2002 | 05:07 AM
paul-e's Avatar
before srpaying the red on do i put somthingon before that?
Old Feb 15, 2002 | 06:02 AM
bmxsteve's Avatar
I didnt
Old Feb 15, 2002 | 02:41 PM
Ravq's Avatar
Be sure to use as many coats of clearcoat as you do paint. It will help to protect the paint and slow the fading process.
Old Feb 15, 2002 | 02:53 PM
paul-e's Avatar
guys i finished it but i messed one of the lights up and got some goon behind the paint and now u can see the goo when my lights are on......
is there a way to take the paint off? paint thinner maybe? any ideas guys?
Old Feb 15, 2002 | 02:54 PM
Ravq's Avatar
It will work but too much will warp the plastic. Be careful.
paul-e's Avatar
and the paint i used is way to thick and doesnt match up that good....i wanna redo them is this possible>?
Old Feb 15, 2002 | 03:13 PM
Uniden's Avatar
I tried painting the outsides and they wound up looking horrible. I'd paint the inners if I were you... no need in paying all that money for something thats going to look like ****
Old Feb 15, 2002 | 03:21 PM
paul-e's Avatar
dam i wanna do them over , you guys think i can strip the paint off? if so what could i use?]
Old Feb 16, 2002 | 08:39 AM
Ravq's Avatar
I didn't have any problems painting the outsides of mine. Just be patient. Use thin coats and give them a lot of time to dry in between.
Old Feb 16, 2002 | 09:00 AM
paul-e's Avatar
i need better paint
Old Feb 16, 2002 | 09:02 AM
Ravq's Avatar
I used Testor's brand Hobby paint and it's held up pretty good but I attribute that to the clear coat on top of it.
Old Feb 16, 2002 | 04:37 PM
paul-e's Avatar
dam yours look nothing like mine
mine looks like red tape on it.....
i tried to use paint thinner but it dodnt work you know somthing that might?
Old Feb 16, 2002 | 06:33 PM
Ravq's Avatar
I don't see why it wouldn't have. I used gasoline (only thing at I had at the time) to remove a little bit of overspray. It's just like the paint thinner and can easily warp the lens. I would think that a little more elbow grease is all you'll need.
Old Feb 16, 2002 | 08:32 PM
paul-e's Avatar
nah man if u could only see it lol
looks like thick red tape and i had thinner on it for like and hour and then i was rubbing it hard and maybe a lil pink was on the towel.......i used body shot paint or somthing like that....anyways its ugly. =(
Old Feb 17, 2002 | 07:35 AM
Ravq's Avatar
Sorry to hear that. If paint thinner won't remove the paint then I'm not sure what to tell you. You could try to sand it off with a very very fine grit. You'd just have to be careful once you started to get close to the lens. I would probably sand it down close enough and then use paint thinner to get the rest off.
Old Feb 17, 2002 | 03:59 PM
paul-e's Avatar
someone said turpentine......thx for your help though=P
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
doctorpullit
Apr 23, 2017 05:35 AM
Luigi623
Sep 21, 2015 01:42 PM
