VB Install Problem
Old Feb 16, 2002 | 04:14 AM
Shadow's Avatar
VB Install Problem
Just finished an all night install of the VB mod, and now I'm having a big problem. The car won't go into any gear. Nothing happens when I put the car into gear, it's still in neutral the whole time. And I can't push the shifter into 1st. I think maybe I didn't get the shift linkage back in the right spot. Everything else I triple checked, but that I can't remember checking. Would that cause this problem?
Old Feb 16, 2002 | 06:56 AM
TILLEYS99's Avatar
Lives in a 11sec maxima
Re: VB Install Problem
did you put the shaft in the VB that connects to the linkage I just sent mine out and when I was pulling my VB out it fell out.
Old Feb 16, 2002 | 07:00 AM
mzmtg's Avatar
Minister of Silly Walks
That wing is nasty....
Old Feb 16, 2002 | 07:03 AM
TILLEYS99's Avatar
and what does that have to do with a VB, opinions are like a$$holes everyones has em.
Old Feb 16, 2002 | 09:41 AM
Don in Texas's Avatar
Its the manual linkage pin. I hope you didn't bend it.
You have to put the pin around the linkage at the same time you are putting the VB back. Before you open up the pan again, put the car in neutral. You will need to remove the VB if the linkage pin is binding, or not installed correctly, or bent.
Before you install the pan again, get someone to shift the gears for you (while you are under the car) to ensure smooth operation of shifter.
its been several weeks with that VB, when you gonna finish? tick-tock....lol
Old Feb 16, 2002 | 05:12 PM
Shadow's Avatar
Thanks guys, fixed it and everything is great now. I can finally hit full boost without the tranny slipping.
Don, the VB is going out on Monday, sorry about the delay, it was just really, really busy. Didn't mean to contribute to your core problems.
Old Feb 16, 2002 | 05:23 PM
ptatohed's Avatar
Licensed to Spell
:o)
I second that. What did you do to that poor car Tilley?
Old Feb 16, 2002 | 05:25 PM
RedMax95's Avatar
you forgot "and they all stink"
Old Feb 16, 2002 | 05:46 PM
ereet's Avatar
I feel for ya having to open the tranny up again to fix that ****. I had to do mine 3 times, lost the spring the first time, broke the gasket the 2nd.
Old Feb 16, 2002 | 05:52 PM
paul-e's Avatar
you feel a big difference with the vb? woth the money?
Old Feb 16, 2002 | 08:55 PM
RS Motorsports's Avatar
I just road in a max with the vb mode done and its a big difference, I would highly recomend the buy i will be purchasing one probably in the spring.
Ryan
Old Feb 16, 2002 | 09:25 PM
Shadow's Avatar
Big difference. Under normal cruising, the car shifts faster, it's noticable compared to the stock shifts which are seamless. But when I floor it, the shifts are very quick. My car is supercharged, and before, when the car shifted, the tranny would slip. I couldn't hit full boost without having the tranny slip and cause my to bounce off the rev limiter. Now, I can floor my car, and the car will shift perfectly every time. A couple of times, my car would start to shift at 5.5K, and not finish the shift until redline. But the VB cured that.
Old Feb 17, 2002 | 06:34 AM
sp6040's Avatar
vb
Quoted Message:
im so jelous so does Don have any vb available to ship out? or do you have to send him yours first?
Old Feb 17, 2002 | 03:54 PM
jdmmax's Avatar
HELP!!!!!
i can't get the vb hareness through
did you dissconnect the intire thing or did you disconnect it closer to the white thingy in the tranny. HELp i am stuck
Old Feb 17, 2002 | 05:19 PM
redmaxpa007's Avatar
i SeE what you did therE
Re: :o)
dude.. who are you to talk about wings??? it looks like yours will fall off??
your "addition" makes you car look cheap...
Old Feb 17, 2002 | 05:30 PM
TILLEYS99's Avatar
Re: Re: :o)
I second that jeff his look like a wannabe type II stillen.
Old Feb 17, 2002 | 06:22 PM
thebigsadler's Avatar
Re: Re: Re: :o)
i'm just glad when we raced on the highway that you pulled about 12 car lengths on me from 60-100.. that was frickin sweet.. not
Old Feb 17, 2002 | 06:53 PM
Shadow's Avatar
Re: Re: VB Install Problem
You have to disconnect the harness at the top of the tranny, underneath the intake. There's a clip on the plug at the top of the tranny, right above the valve body. Unclip that, the plug should come out, then work the harness all the way down through that hole. It took us 2 hours to get the harness down there because it got stuck between the tranny, the engine mount, and a few other things.
Originally posted by jdmmax
HELP!!!!!
Old Feb 18, 2002 | 12:34 AM
jdmmax's Avatar
Re: Re: Re: VB Install Problem
ok thanks i just ended up unbolting everything the harness was getting chuaght. whew i was just panicing!!!!! but i solved everyproblem. THanks Shadow
Old Feb 18, 2002 | 01:43 PM
ptatohed's Avatar
Licensed to Spell
Re: Re: :o)
Yeah, I guess you're right. I should take it off. And then I'll put on a front license plate with a big, huge Nissan logo, some awesome wind defelctors all over my car and then to top everything else off, some fancy pinstriping right down the side. Then I won't look 'cheap', right?
Old Feb 19, 2002 | 04:24 AM
Re: Re: Re: :o)
ok.. look pal.. the pinstriping adds 2-3 hp easy..
the wife wanted the wind deflectors,
and the nissan logo liscene plate is a fad i been going through..
Lakersallday24
Nov 7, 2024 07:31 PM
Cotozic
Jun 28, 2017 08:01 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Tha'-Max
Aug 30, 2015 01:14 AM
kirkhilles
Aug 8, 2015 10:53 AM
