DTC 0908 diagnostic help
Old Feb 18, 2002 | 10:02 AM
RandyMax's Avatar
Hi there, newbie here...
I have a 96 SE. The check engine light went on over the weekend. I followed the instruction to get the DTC, and it returned 0908 which is a coolant temp sensor malfunction.
Since this is the first time I try to work on a car, I need help.
Questions:
First of all, am I look at the right thing?
http://www.imagestation.com/picture/...2.jpg.orig.jpg
http://www.imagestation.com/picture/...5.jpg.orig.jpg
If so, I couldn't quite reach it, so I follow the wiring to a conector, detached it, and measured the resistance between the two leads (see pic 2: red dots indicate the wire I traced, yellow circles the connector). I couldn't get a reading. Does that mean the sensor is bad, or am I doing something wrong?
http://www.imagestation.com/picture/...4.jpg.orig.jpg
Third, if in case the sensor bad, how can I replace it? What kind of tools would I need?
Thanks!!
EDIT: direct link to imagestation doesn't seem to work. to view pics please cut and paste addresses above. thanks!
Old Feb 18, 2002 | 11:16 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Some good suggestions for how to help your diagnosis can be found through the following results for searching "0908" in the 4th gen forum:
http://forums.maxima.org/search.php?...der=descending
Good luck!
Old Feb 18, 2002 | 11:56 AM
RandyMax's Avatar
Thanks for the reply!
I have already looked search for info on 0908 before. The reason I posted this thread is to confirm with you guys to see if I am performing the diagnostics correctly.
I don't exactly know what I am doing...
Old Feb 19, 2002 | 01:17 PM
RandyMax's Avatar
* bump *
Help anyone?
vybz05
Dec 10, 2015 07:38 PM
ef9
Aug 27, 2015 10:17 AM
Soon2BMaxed
Aug 11, 2001 06:32 PM
