What does the overdrive button do?
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
![](https://maxima.org/forums/images/smilies/support.gif)
The overdrive button toggles overdrive on or off. When off, you are out of overdrive gear which means you in a lower gear which gives you more performance and acceleration. It is a rough explaination but here is a site which gives you more infomation.
overdrive
overdrive
Search is your friend: http://forums.maxima.org/search.php?...der=descending
Just leave it on. Dont worry about it.
If you are in traffic and running between 40 and 60 mph, switching it off will reduce hunting for gears.
Also, when going for top speed leave it off until you redline 3rd gear (see my sig pic). This drops you into 4th gear at a better RPM to keep acclerating.
Re: What does the overdrive button do?
Originally posted by Tbonephile
What does the overdrive on/off button on an automagic do exactly to performance and acceleration?
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
It turns o/d off. Which means your tranny will only use three gears!
Originally posted by kmax97
My OD is always on... is that ok? or should I turn if off at speeds > 50 mph and turn it on for highway speeds ?
![Confused](https://maxima.org/forums/images/smilies/confused.gif)
tarun900
19
12-20-2021 06:57 PM
worldwiderecognized
09-30-2015 01:16 PM
