Where do you connect the window on a n20 set-up?
Old Feb 25, 2002 | 01:17 PM
wicked1044's Avatar
where do you connect the wires to coming out of the box?
Old Feb 25, 2002 | 01:42 PM
Ramius83
What window and what box lol?
Old Feb 26, 2002 | 07:48 AM
wicked1044's Avatar
The window switch. The window switch is a little black box. There are four wires coming out of the box(red,black,yellow,white)
Thanks..
Old Feb 26, 2002 | 08:15 AM
Sprint's Avatar
are you talking about the rpm switch? the relay?
Old Feb 26, 2002 | 08:17 AM
Sprint's Avatar
you must be talking about the rpm switch because the relay is the only other thing with 4 wires and its red, blue, green and orange... and be nice to Ramius.. he is running a 100 shot so he has experience with NOS so he is only trying to help you..
Old Feb 26, 2002 | 08:18 AM
wicked1044's Avatar
talking about the MSD RPM Activated WINDOW Switch... you knew that..
Old Feb 26, 2002 | 08:24 AM
Sprint's Avatar
Originally posted by wicked1044
:rolleyes :mad
I wouldn't know that if i don't have one
mine says NOS on it
Old Feb 26, 2002 | 08:25 AM
Sprint's Avatar
dude if you want help with NOS stuff.. you are going to have to kill that attitude.. because as it stands right now.. you have ****ed off two NOS veterans with your f#cking sh!tty attitude..
keep burning bridges..
Old Feb 26, 2002 | 08:28 AM
wicked1044's Avatar
hmmm. isn't the window switch and the relay to different things??
you still know what i was talking about.
Old Feb 26, 2002 | 08:42 AM
mtrai760's Avatar
'Trynna' is not a word
Check your email...
Old Feb 26, 2002 | 10:03 AM
SuDZ's Avatar
hehe there goes two of the people that could have helped you most if you just calmed down.
Old Feb 26, 2002 | 10:13 AM
mtrai760's Avatar
The red wire goes to a 12v power source
The black wire goes to a ground
The yellow wire goes to the ground of the #1 NOS solenoid
The white wire goes to the stripped coil wire
Old Feb 26, 2002 | 10:20 AM
wicked1044's Avatar
calmed down
i didn't know i was wound up.
Old Feb 26, 2002 | 10:24 AM
wicked1044's Avatar
Thanks Matt..
Old Feb 26, 2002 | 02:37 PM
RKS's Avatar
RKS
Which one is the coil wire? (in the ECU I assume?)
Old Feb 26, 2002 | 03:49 PM
wicked1044's Avatar
no, he was talking about the coils in the engine bay (where your spark plugs go). there are 3 wires coming from each coil. you want the one w/ the spripe on the wire...
Old Feb 26, 2002 | 05:46 PM
RKS's Avatar
RKS
I talked to MardiGrasMax briefly this weekend and I just want to make sure I am doing the wiring correctly. (Matt really knows his stuff )
I have a question about hooking up a different Window Switch that requires a relay to connect to the NOS solenoids. I guess my actual switch connects similarly to the coil wire as the NOS/MSD types. However I need to connect the switch to the relay any detail instructions on how to do that?
Old Feb 26, 2002 | 05:49 PM
Sprint's Avatar
the coil wire goes to the rpm wire on the ECU
Old Feb 26, 2002 | 06:17 PM
RKS's Avatar
RKS
So I do connect the window switch to the ECU on the coil wire and then connect the relay to the switch and the relay controls the solenoids?
If I remove the ECU from its bracket, which wire is the coil wire since it probably doesn't matter which cylinder it is from? Let me know if I am not grasping the obvious, thanks.
Old Feb 26, 2002 | 06:23 PM
Sprint's Avatar
the way i have my NOS switch wired.. i have the coil wire going inside the car to the rpm wire from the ECU.. i forgot which color wire it is on the ECU.. argg... but when you go on the passenger side of the ECU you can pull the middle screw off remove the plastic area and you will see all the ECU wires.. i know the wire is in the manual for the rev speed meter.. i will check around for the color for you..
Old Feb 26, 2002 | 06:28 PM
Sprint's Avatar
from the man himself
Originally posted by sx7r
i didn't tap into the coil, i tapped the tach wire off the ECU.
RED - 12V constant
GREEN - nitrous relay ground, after your full throttle switch
WHITE - Tach wire off the ECU harness. This tach wire is a white wire with a green stripe. below is a picture of the ECU harness so you can see where the wire is. it's going to be wire #5.
BLACK - Chassis Ground
below is a picture of where the tach lead is located on the ECU harness:
Old Feb 26, 2002 | 06:52 PM
RKS's Avatar
RKS
Thanks...
Old Feb 26, 2002 | 07:39 PM
wicked1044's Avatar
Matt said to hook it to the coil in the engine.
to each his own...
Old Feb 26, 2002 | 08:52 PM
Synki's Avatar
I already talked to you about this but i will post just incase Wayne.
White goes to coil pack & yellow goes the one fo the terminals on the throttle switch.
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
lrb6805
Sep 24, 2015 05:03 PM
