already searched... shaving the keyhole
:o)
Not sure what you mean by 'how' sex.? How does one shave his/her doorhandles? How does one shave his/her stock antenna? How does one shave his/her windshield squirters? The answer is you take it to a body shop that has experience in shaving and have them remove your key cylinder, fill it in, sand, prime, etc. and then paint the WHOLE (yes the whole) trunk. Be prepared to spend several hundred minimum.
Re: :o)
Re: Re: :o)
Originally posted by FJC
Yep.... Not worth it unless you have a few bucks....
I didn't say it wasn't worth it! I feel it's mandatory!! I HATE unsymmetrical things...
Re: Re: Re: :o)
i had mine done for $40 and you can harldy see it.
Ant
Re: Re: already searched... shaving the keyhole
Originally posted by dko
bodyshop + 14 lbs of bondo
i would take it to a body shop that does custom work and they do it on a readily basis. To be done right, the whole is welded with metal and like said before..the WHOLE trunk is painted.
Re: Re: Re: already searched... shaving the keyhole
Originally posted by Swafford98
what bodyshop do you use??? Fill a hole that size with bondo and give it a few months and see what happens. i dont know where you guys get this perception that you fill every hole with bondo. Bondo does not have magical powers to make holes go away.
Re: Re: Re: Re: already searched... shaving the keyhole
Josh, (Swafford98) works in a body shop. And yes, you cannot fill that hole with just bondo. Do that, and the hole will cave in within 6 months, as soon as the temperature changes. I know a few body shop guys, and everyone agrees that the proper way is to pull the lock cylinder, weld a metal plate in, grind it down, and then use a small amount of filler to smooth everything up. A lot of shops will use only bondo, but that's the ghetto way, and the car will look like crap after a while. And it isn't cheap, that's why I had mine done when they were painting the car already.
it's a short and sweet answer. why would you take my word as gospel; am I walking on water here? you are correct in thinking that the whole trunk needs to get repainted, but I don't believe that the hole needs to be welded over. of course I could be wrong, but it sounds a bit hard to get everything to look right if you actually do metal work there.
Re: Re: Re: Re: Re: already searched... shaving the keyhole
P.s. yes, my guy welded a plate from behind and filled in from the front.
alixc
Aug 11, 2020 01:48 PM
rbaker100
Sep 6, 2015 02:46 PM
