what is the best tool to use for cutting out the florecent part for red clear tails
Old Mar 3, 2002 | 01:29 PM
max99's Avatar
I'm in the process of clearing out my tails right now and I have the orange out now and have started cutting but I already know its going to be a pain in the @ss so before I crack to much of the light cover then I figure I would ask what is best to use for cutting it perfect.
Max99
Old Mar 3, 2002 | 02:09 PM
JAY25's Avatar
Re: what is the best tool to use for cutting out the florecent part for red clear tails
USE a dremel to cut it, very fast and smooth cut
Old Mar 3, 2002 | 02:15 PM
NickStam's Avatar
dremel or a soldering iron with a ruler or something
Old Mar 3, 2002 | 04:16 PM
Jime's Avatar
I don't have a dremel so I used a jigsaw and heated up the plastic with a heat gun occasionally to keep it somewhat soft so it wouldn't crack. Works pretty good. Depends on what tools you have available I guess. Good Luck
Old Mar 3, 2002 | 09:29 PM
syc's Avatar
syc
Just use the utility knife with a ruler and then use sand paper.
Old Mar 3, 2002 | 09:52 PM
Nismo's Avatar
I use a dremel with the fiberglass reinforced cutting disc
Old Mar 3, 2002 | 11:43 PM
NISMOPower's Avatar
i used a dremel and i tried cutting it but it was choppy and rigged. Maybe i used the wrong tool should i go and fix it cause the sheet i used wasn't as clear as the reverse light.
Chris
Old Mar 4, 2002 | 01:30 AM
SLC I30t's Avatar
I used a fork and spoon.
I think we used a dremel and about 4-5 discs. he he he Relief cuts are worth your time!!!
vingodine
45
May 21, 2016 12:46 PM
tommy20020
Jan 6, 2016 04:05 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Nitehawk11sv
Aug 31, 2015 02:43 PM
220k+ A32
Aug 17, 2015 03:57 PM
