New front brake pads & got rotors turned....
Old Mar 5, 2002 | 10:03 AM
97MaxSE's Avatar
Hey last Friday i got new front brake pads and had my rotors turned as well. My brakes still squeak on & off (not nearly as bad before I took my Max in though) But when i am driving, you can sometimes hear a squeaking sound.... I need your all's help. Thanks.
Old Mar 5, 2002 | 10:06 AM
KWheelzSB's Avatar
Re: New front brake pads & got rotors turned....
Give the pads a few hundred miles (say, 300) to "bed in" to the rotors - if they're still squeaking after that, get back to us.
Also, make sure you break them in using only modest brake pressure during this period - avoid hard braking, except in case of emergency. If you don't, it's possible to "glaze" the rotor surface.
Old Mar 5, 2002 | 11:38 AM
NmexMAX's Avatar
dot dot dot ...
Re: Re: New front brake pads & got rotors turned....
i always hear about Maxi brakes squeaking, mine squea the firs few hundred miles but then they quiet down...
Old Mar 5, 2002 | 05:35 PM
97MaxSE's Avatar
Re: Re: Re: New front brake pads & got rotors turned....
Thanks.....but only 2 responses? Come on I need some help. Also, It snowed the other night & I slid into a curb w/ my wheels turned to the right. Today I noticed that when I steer to the right I hear a squeaking noise. What in the world could cause this? HELP.....
Old Mar 5, 2002 | 06:33 PM
costcowholesale's Avatar
yr rotor might be seized to teh pads? that happened to make & it made noise when I'm not braking
Old Mar 5, 2002 | 06:57 PM
97MaxSE's Avatar
so what did you do?
Old Mar 6, 2002 | 06:33 AM
97MaxSE's Avatar
Hello.....I need some responces....PLEASE
Old Mar 6, 2002 | 06:38 AM
Vyrus's Avatar
Is the braking better?...
I am planning on getting new pads and my rotors resurfaced tomorrow. Are the brakes much improved (Granted the squealing isn't, that's what this post is for - but is the stopping power improved)?
Thanks,
-Cyrus
Old Mar 6, 2002 | 07:02 AM
97MaxSE's Avatar
Re: Is the braking better?...
Thanks,
-Cyrus
Definately.....you can tell a difference in your stopping power. @ least I could when I got mine back.(So do you have any insight about the squeaking?)
Old Mar 6, 2002 | 07:20 AM
ivolley's Avatar
Re: Re: Is the braking better?...
I am not a big fan of turning rotars, I just replaced my pads, I used Bendix pads and I do not have any squealing. Previously when I have had rotars turned I think eventually (probably within a year) your rotars will be thin and may cause vibrations (even with brand new pads) THis is the first time I have not had the rotars turned and this is the quietest the car has been.
Vyrus's Avatar
Did you bleed your brakes? That could be one cause of the squealing. Other than that I suggest you really stomp on them to wear them in a little and see if still squeals. But maybe it just need time.
-Cyrus
Old Mar 6, 2002 | 07:32 AM
97MaxSE's Avatar
Re: Re: Re: Is the braking better?...
Buddy you are supposed to have your rotors turned every now & then....
Old Mar 6, 2002 | 09:01 AM
Chunger's Avatar
My other car is a Hybrid
Noisy brakes can be from several sources:
1) pad material (probably not your problem)
2) missing shims that weren't transfered from old pads
3) not using 'disc quiet' goop or such
4) brakes haven't been broken in (as stated in a previous post)
5) foreign material lodged between pad and rotor
BTW - not bleeding the brakes doesn't cause any noises... only causes reduced braking when you have air in the system.
Old Mar 6, 2002 | 09:38 AM
ivolley's Avatar
Re: Re: Re: Re: Is the braking better?...
I agree but most shops (atleast my experience has been) they want to cut the rotars. I have had rotars cut and within 3 months I had vibrations becuase the rotars were cut too thin or too close to specs. Stock rotars are not expensive, on my previous Maxima I opted to have the pads replaced and new rotars installed @ 85K miles (They had been cut by previous owner). The rotars on my current car were in very good shape so I decided to add pads, if i develope noise in the near future I made a mistake but If I continue to have a nice quiet braking experience I would have made the right decision. And besides you asked for our opinions and this has been my experience.
Old Mar 6, 2002 | 11:21 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
Re: Re: Re: Re: Re: Is the braking better?...
cutting rotors is another term for resurfacing or turning rotors.
what kind of pads are you using 97MaxSE? usually squeaking noise is associated with installtion. ive never had one brakejob comeback due to noise. I also dont belive brake disc quiet(goop) is necessary if the job is done correctly. If a shop did it for you you should bring it back to them and have them look at it.
Old Mar 6, 2002 | 11:48 AM
97MaxSE's Avatar
Re: Re: Re: Re: Re: Re: Is the braking better?...
So your saying that my brakes shouldn't be squeaking? I am confused by your post.
Old Mar 6, 2002 | 02:22 PM
mike_rose's Avatar
the squeaks can also be caused by vibrating parts installed with the brake pads try putting "goop" or antisieze compound on these parts to prevent vibrating. this might help.
Old Mar 6, 2002 | 02:30 PM
emoore924's Avatar
could be
A couple more questions that aren't clear to bme from reading the stuff above...
1) Does the car squeak squeak squeak, then when you put your foot on the brake, it stops?
-or-
2) Is the car quiet when you're running, then the car squeeeeeeeekkks when you put your foot on the brake
Can you tell whether it comes from the front or the back or both?
Along with the things already mentioned,
(1) could be a caliper where the piston isn't retracting all the way and it is allowing the brake pad to drag on the rotor, or it could be a e-brake cable that is sticky or frozen again causing the caliper to drag. You'll probably get *really* hot rear rotors if the cable is a problem.
(2) Could be any of the things mentioned before, installation, shims, goop, cheap pads, glazing, etc.
I just had brakes done on my fronts; new factory pads and rotors turned. Alsolutely no problems. And, the wheels are *much* cleaner now with the factory pads.
BTW, the rotors do have minimum thickness spec and runout (wobble) spec (see potato chip analogy below) and the brake shop is not supposed to turn them once they fall beyond that spec -- the operative word there being "supposed". Think of a potato chip. Hold it in the center and spin it around and that's what an out-of-true rotor does. Because heat is your enemy, and the more metal, the better the heat sink, the less metal on the rotor (as removed by turning), the more likely the rotor is to warp. In a worst case if you go beyond spec, the rotor can crack or break causing catostrophic failure (autotechno speak for a smash-up).
Hope this helps.
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
