Anyway to check which O2 sensors are dead for a 95?
Old Mar 5, 2002 | 05:11 PM
Finality's Avatar
I just filled up my last tank and I got 17 mpg with 50/50 c/hwyk driving .
Last tank was 22 and the one before 23. I figured that was in-line with what I was driving. My guess is one of the 4 O2 sensors are dead either that or all of them are dead ?
Any way for me to check and see which O2 sensor is dead? I understand the 95s engine light does not come on?
Old Mar 5, 2002 | 09:29 PM
BEJAY1's Avatar
Conecarver
Don't know why your MIL won't light but you can test em one by one with a digital voltmeter. Check for correct signal voltage on each. Then check the battery voltage supply and resistance of each O2 heater.
Too bad you don't have an OBDII plug to just scan it
Old Mar 5, 2002 | 11:19 PM
Eric L.'s Avatar
If your O2 sensor is off, the MIL will light up. If you have any of the shop manuals (Chiltons, Haynes, Nissan) they list the procedure for testing the O2 sensors.
Old Mar 6, 2002 | 05:51 AM
BRIGBOY's Avatar
1995 maximas check engine light will come on,
,if the O2 sensor is faulty. And you have 3 of them, 1 in each downpipe and 1 in the cat.
Old Mar 6, 2002 | 06:29 AM
caneyebus's Avatar
i got a 95 also and i replaced 2 of my sensors if that means **** to you!!!
Old Mar 7, 2002 | 07:46 AM
Phoenix25's Avatar
Beleive me you that light does work. The 95s are known for faulty or over sensative OS2 sensor. In my case whenever my wife uses cheap gas my check engine light comes on even though I've have the sensors replaced a while ago. Once I put in 93 octane the light goes back off after a few tanks. I just hate when it comes on cause I never know if its a true issue....
Old Mar 7, 2002 | 08:18 AM
BRIGBOY's Avatar
Why not?
If you pulled the code you would know if its a true issue!!! Directions are in the "Important" titled thread up top.
Old Mar 7, 2002 | 09:48 AM
Eric L.'s Avatar
You could be tripping the knock sensor, not the O2 sensor, with cheap gas.
Old Mar 7, 2002 | 10:25 AM
Phoenix25's Avatar
__________________________________________
I was always told it was my o2 sensor - Interesting... Thanks! I'm glad I joined this site!!!!! Very informational! Never realized how cool my Max is!
Old Mar 8, 2002 | 09:17 PM
j_bryan's Avatar
Re: Anyway to check which O2 sensors are dead for a 95?
did you obtain the trouble codes? my check engine light (CEL) just came on tonight. i pulled the codes and i got 3 codes!
knock sensor
upstream left bank O2 sensor
upstream right bank O2 sensor
just ordered a new knock sensor online, but am not sure what to do about the 02 sensors..
Old Mar 9, 2002 | 06:13 AM
NikeGal's Avatar
Well if the light doesn't come on I dont know what that yellow light in the corner of my dash is??? My 2nd O2 sensor is bad. I just took my car to my mechanic and he hooked it up to the machine and told me which one it was...
mvm062
Nov 30, 2020 09:00 AM
markevans999
Sep 10, 2015 04:29 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
