Charging or grounding problem
Old Mar 6, 2002 | 07:24 PM
maximaking's Avatar
Today when I hit a bump my charging light and brake light both came on..... A call to Nissan reveals a bad alternator over the phone. Car steill runs alternator is less than a year old. Car was recently in an accident however engine bay shows no signs of a bad ground Any ideas?
Todd
Maximaking@aol.com
Old Mar 6, 2002 | 09:44 PM
Bags's Avatar
VG Ridah's Biatch Hoe
This is a classic sign of a LOOSE wire or connector.
I would check the impedance(ohms) of the ground on the alternator and the motor. If they are not the same.
Your looking for a high reading.. I would try and compare it to another max of the same year... If yours if over 1K higher than the other max I would look at that as being the problem.
Another thing is, after the "bump" is the lights always on?
If not just sometimes, as your checking your ohms have someone shake the car to see idf it changes.
Also a LOSSE realy or fuse could cause this. Poor conduction.
Check all your realys and fuses.
Hope this helps
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
pktaske
May 6, 2016 07:49 AM
jfl330
Sep 4, 2015 01:44 PM
pktaske
Sep 4, 2015 08:40 AM
