how important is it to replace the knock sensor?
Old Mar 7, 2002 | 07:51 PM
mohfo's Avatar
How important is it to replace the knock sensor? Should i do it right away?
Old Mar 7, 2002 | 08:31 PM
DCmax's Avatar
Re: how important is it to replace the knock sensor?
Depends. You wont really notice a difference in daily driving, but at the track you will see a difference on paper.
Old Mar 7, 2002 | 08:35 PM
KWheelzSB's Avatar
Important if it needs replacement. If you're not getting a K/S code from the ECU, don't bother. You'll just be wasting your time & $.
Old Mar 7, 2002 | 08:37 PM
DCmax's Avatar
Good point, I had just assumed mohfo had a malfunctioning KS.
If you havent got a KS code, ditto on what KWheelzSB said.
Old Mar 7, 2002 | 11:31 PM
SuDZ's Avatar
Re: Re: how important is it to replace the knock sensor?
I gotta do mine and I am feeling it in daily driving.
SuDZ
Old Mar 7, 2002 | 11:42 PM
Stillen_I30's Avatar
I felt mine in daily driving. when the engine was cold, it felt as if it was hesitating around 2000 RPMs. theres definately a lot more power now, and the gas usage seems a little better.
Anybody know if the bottom of the knock sensor (which is all metal) is what grounds the thing thru the bolt since theres only one wire giong into the sensor? Mine was all dirty underneath and I believe that may have lead to its malfunction. just a thought...
Old Mar 8, 2002 | 08:54 AM
DCmax's Avatar
That's an interesting thought, the new KS had a flawless underside of flat metal and my old one had some rust and the metal was pretty worn.
Old Mar 8, 2002 | 12:46 PM
SuDZ's Avatar
I wonder how it got rust on it. It would seem like not much moisture gets down there.
SuDZ
Old Mar 8, 2002 | 12:56 PM
DCmax's Avatar
SuDZ
Ha, EVERYTHING on my car has rust...well a lot of it does. I can't explain how agonizing it was installing the Y-Pipe (Exhaust Manifold bolts) and getting off some of the bolts when I installed new shocks and struts, not to mention I still can't get my front rotors off.
Old Mar 8, 2002 | 01:20 PM
SuDZ's Avatar
Did you reuse the same old bolts?
SuDZ
Old Mar 8, 2002 | 01:59 PM
jayanth's Avatar
as far as my knowledge goes, Knock sensor helps in preventing engine knocks due to bad/lower grade gas and other reasons leading to premature ignition.Your ECU should retard/forward your ignition timing/spark advance based on the input from the knock sensor.Thus it provides your ECU with vital info which helps your car perform better.
my 2 cents!
take care,
jayanth
Old Mar 8, 2002 | 03:21 PM
SuDZ's Avatar
my 2 cents!
take care,
jayanth
Also as someone in another thread said, it seems to prevent having other O2 sensors going out on you. So might as well change it before you gotta pay even more in the long run.
SuDZ
Old Mar 8, 2002 | 09:12 PM
DCmax's Avatar
SuDZ
I replaced the exhaust bolts, the suspension bolts were re-usable.
Old Mar 8, 2002 | 09:55 PM
mohfo's Avatar
thanks guys
thanks guys I guess I will replace it. By the way I took it to the shop, that's how I know i had to replace it.
Old Mar 9, 2002 | 12:37 AM
KWheelzSB's Avatar
rotors seized on hub?
. . .not to mention I still can't get my front rotors off.
Now see this:
http://forums.maxima.org/showthread....ight=extractor
kjlouis
Nov 24, 2018 06:09 AM
AnsonJ
Jun 2, 2017 01:35 PM
maxinout93
Oct 27, 2015 01:29 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxinout93
Aug 20, 2015 02:17 AM
