Help. Replacing factory fog lights
Old Mar 8, 2002 | 12:39 PM
Stillmatic's Avatar
I already checked the search but couldnt find the answer i am looking for.
I have some super whites i wanna put in. So i unscrewed the little cover by the light. then there was/is two screws that look like they have to come off to remove the light part to get to the bulb. Well those screws wont unscrew. I have lost my owners manual, so i cant check that out. am i doing everything right. any other way i should be doing this. can i get to it from the hood. Please help me out. I really appreciate it, as these the the last light for me too do.
Sillmatic
Old Mar 8, 2002 | 01:05 PM
Stillmatic's Avatar
bump
Sorry just hoping to find a answer before dark
Old Mar 8, 2002 | 01:22 PM
Toolrocks's Avatar
This probably won't help but I have a 95 SE and to replace the FOG lights on my car I have to push in and up on the inside end of the lens to remove a clear/reflective piece that then gives me access to a single screw. With the clear/reflective piece off and the screw out the lens then pulls out as if it had a hinge on the side opposite the screw. Then I just dis-connect the wire connector and free the bulb by removing a metal spring lock. I can also access mine from under the car, but have to remove a few screws holding the splash guard up to the underside of the engine. Hope this helps. One last thing; make sure you don't touch your new bulb w/ your fingers. Good luck.
Old Mar 8, 2002 | 01:27 PM
1FSTMAX's Avatar
There is a little piece of plastic covering two small bolts. You need to remove that. Then you remove the two small bolts, and the fog light should come free.
Old Mar 8, 2002 | 01:41 PM
Stillmatic's Avatar
Yeah i removed that little piece of plastic. but the two small bolts will not unscrew. I am a big guy with some muscles lol. but i cannot get those screws to come off.
I will try your idea Toolrocks. any other ideas
Old Mar 8, 2002 | 01:55 PM
Toolrocks's Avatar
If you're able to spin the screws can you pull out on them as your turn them. Maybe they've been screwed in past the thread lines? Or maybe their is one of those clips, like come w/ some speakers, that is spinning behind the screw. If you can't get them out by pulling outward on the screw until it starts then I would just gain access to the fogs from underneath. Good luck.
Old Mar 8, 2002 | 02:05 PM
Stillmatic's Avatar
nope cant even get the screws to spin at all. getting to dark now. DAMN. i wanted to drive around with them tonite. ah well. looks like tomorrow, i go underneath
thanks for help, very much appreciated
Old Mar 8, 2002 | 02:13 PM
1FSTMAX's Avatar
use a socket and a ratchet.
Old Mar 8, 2002 | 02:28 PM
Big_Ham's Avatar
MaximaFreak
Ditto. I believe those bolts are not just phillips, but also 10mm. Can anyone confirm or deny this?
Old Mar 8, 2002 | 03:08 PM
1FSTMAX's Avatar
yep, 10mm socket
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
MikesChevelle
Aug 6, 2015 11:36 AM
