Rear Sway Bar Question
Old Mar 12, 2002 | 09:39 PM
SoccrZ's Avatar
I'm thinking about buying a RSB from Custommaxima.com. For those of you who have installed this, how long does it take to install and how easy is it to install? Thanks.
Old Mar 12, 2002 | 09:41 PM
jargoone's Avatar
Re: Rear Sway Bar Question
1.5 hours with no experience and the right tools. Easy.
Search.
Old Mar 12, 2002 | 10:05 PM
Toolrocks's Avatar
IT's very easy, however, if you get an Addco be prepared. They have shipped some w/ bad hardware. I say bad meaning you have to drill out the holes on some of the attaching plates to get the brackets to fit. You'll know what I mean if you get a bad set. Otherwise it's a piece of cake.
Old Mar 12, 2002 | 10:11 PM
Solo950's Avatar
It was really quick (1-2 hours). I used wheel ramps which made things nice and easy.
Toolrocks's Avatar
Old Mar 13, 2002 | 05:54 AM
araffio's Avatar
This is incorrect. Some people who installed the Addco didn't give it enough time or effort to get the hardware to fit. If you run across this problem, which you probably will, all you need to do is MAKE SURE you're putting the bracket on completely stright with both bolts going through the plate at the same time. It will be a tight squeeze, but it will fit. Doing one side at a time makes it seem as though it will never fit. To make it a little easier, simply bend the bolt a tiny bit around the frame. Go with the Addco, its cheaper but performs very well. You'll notice a drastic difference.
Old Mar 13, 2002 | 06:15 AM
DARTHSWAN's Avatar
I had no problem at all, at most it took an 1 hour, and that was pushing it. My father was surprised I put it on that quick.
K
Old Mar 13, 2002 | 06:27 AM
clee130's Avatar
2 hours!?
Well ... I suppose if it's your first time ... maybe... but if you get someone to help you out that has done it before, shouldn't take more than 45 minutes.
Old Mar 13, 2002 | 10:05 AM
araffio's Avatar
Be sure to use the correct plates with the correct bolts. They are slightly different. This will cause them not to fit if they are interchanged.
Old Mar 13, 2002 | 11:30 AM
DARTHSWAN's Avatar
Set it up on the floor first, then proceded to the car.
Old Mar 13, 2002 | 11:34 AM
jargoone's Avatar
Originally posted by araffio
This is incorrect.
No, it's not. I got a bad hardware kit with mine, a couple parts missing and a couple extra. I could still install it buy purchasing extra nuts. Some people posted pictures of what they got, and there's no way they could've made it work.
Old Mar 13, 2002 | 12:19 PM
Toolrocks's Avatar
Sorry but I'm not incorrect. I am fairly mechanically inclined and have installed a total of 4 of the Addco, and 2 of the Stillen RSB's and I can tell you, without a doubt, that sometimes the hardware is not machined properly and doesn't fit without modification for the Addco's. In any event it's a great mod and the benefits greatly outweigh the cost. To further that benefit go with the less expensive Addco.
Old Mar 13, 2002 | 12:22 PM
araffio's Avatar
My bad...Didn't mean to second guess, just thought that it was a universal problem, not that parts were missing or whatever.
Old Mar 13, 2002 | 12:30 PM
Toolrocks's Avatar
It's all good.
ef9
Aug 27, 2015 07:21 AM
seesole
Aug 26, 2015 11:22 AM
Dasmith
Aug 25, 2015 10:15 PM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
