Rims....?
Old Mar 14, 2002 | 08:47 AM
Mr Shwang
Rims....?
If i get 18in Konig do i have to change or cut or do anything to make them fit with steering or anything?
Old Mar 14, 2002 | 09:19 AM
BlkCat
No. Lots of guys here have 18" rims. If offset is between 35mm to 40mm you're ok.
Old Mar 14, 2002 | 10:28 AM
95emeraldgxe's Avatar
you can fit upto 19 inch rims with no problem at all on a max =) - its on the FAQ's
Old Mar 14, 2002 | 01:06 PM
OgreDave's Avatar
Re: Rims....?
you need 5x114.5 aka 5x4.5 lug pattern. for the closest to flush (front) .. you want +38 to +42 offset.
make sure you dont forget to get the hubcentric rings for the maxima. i think that covers everything but im super tired so i might be outta it.
Old Mar 14, 2002 | 01:19 PM
SuDZ's Avatar
Re: Re: Rims....?
What are hubcentric rings?
SuDZ
Old Mar 14, 2002 | 01:36 PM
njmaxseltd's Avatar
Re: Re: Re: Rims....?
SuDZ
They go on the hub of the car, just over the center cap where the axel nut is. That allows the aftermarket wheel to rest on the hub nice and snug. Also makes sure your wheel gets centered correctly on the hub.
The Nissan wheels fit snugly on the hub, aftermarkets don't fit snug, there usually made larger to fit an assortment of vehicles. The rings are spicific for each wheel and car type to assure the proper fit. They should come with the purchase of new wheels. You dont need them to mount the wheels, but they do help.
Old Mar 14, 2002 | 02:24 PM
SuDZ's Avatar
Re: Re: Re: Re: Rims....?
Oh ok, so when I get the wheel it comes with it anyhow. Thats cool since I thought it might have been something extra I had to buy.
Anyone know a site that sells Enkei wheels? I cant find the RPO2's and I wanna see if they will fit on a Maxima.
SuDZ
Old Mar 14, 2002 | 02:53 PM
OgreDave's Avatar
njmax hit it on the money, i was just pointing it out just in case you were buying used.. off another ytpe of car.
note, supposedly all aftermarket wheels are drilled to the same size (73mm-ish) .. and all you need is hubcentric rings for your car, should work on any aftermarket wheel.
Old Mar 14, 2002 | 02:57 PM
BlkCat
Re: Re: Rims....?
+42mm? I've read that you can't go beyond +40mm. What happens if it is at +42 or +43mm? What are the maximums?
Old Mar 14, 2002 | 03:48 PM
1MAX2NV's Avatar
Most Konig are 42mm. They will fit. 2MM is tiny.
Old Mar 14, 2002 | 07:03 PM
OgreDave's Avatar
Nah. +42 is fine, if you wanna see +42 vs +38 i have pics at
http://intolerable.net/ogredave/Maxima/
the axis are +42, and you can see they sit a lil in. +38 is pretty much flush in front, a lil in in rear.. not much u can do about the rear.
2LEET4U
27
Mar 20, 2007 01:06 PM
shift_2kmaxima
Feb 26, 2006 06:46 PM
96customax
18
Jan 24, 2006 04:29 PM
AzNx2k2xSEXima
Mar 14, 2003 05:11 AM
NYCe MaXiMa
Apr 21, 2001 03:36 PM
