clearance light rewire and headlight housing q's
Old Mar 20, 2002 | 06:07 PM
kmax's Avatar
I searched first but still have questions. After reading chestons how2 for rewiring the clearance lights I'm not sure what he means by marking a wire with a red pen and then doing something with that?
Isn't this just a matter of switching wires. Only one wire is used from the factory and that is the lower wattage wire. So if I desolder the one that's connected and solder the other wire to that connection I should be done, right?
Also, my headlight blew up in it's housing. After I pull the housing out, can water be used to flush out the glass and dust remains from the bulb that are in the housing? Or should I use compressed air?
Will my headlight need to be realigned after taking out the housing?
Thanks in advance.
Old Mar 20, 2002 | 06:14 PM
PRPmax's Avatar
I'm really not sure on the wiring part. Are you doing the parking lights?
But for the bulb blowing up in the housing, you might want to use a compressed air can or a very flexible vacuum hose. Don't use water to flush it out, you'll get that cloudy look afterwards.
Old Mar 20, 2002 | 06:40 PM
kmax's Avatar
Are you doing the parking lights? No, the lights next to the headlights. Thanks, I'll use compressed air.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Sep 8, 2015 02:36 PM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
