Computer reset
Old Mar 22, 2002 | 12:34 PM
Maxstradamus's Avatar
Computer reset
Hi there
I just got my new exhaust system put in (y-pipe, catalytic converter, cat-back exhaust) and i'm getting check engine light all the time. I was told that it might be becuase of the computer not reprogrammed or something like that. I figured that if i reset the computer, everything will be fine...how do i do that??? I also heard that unhooking the battery and hooking it back up will do the trick but i'm not sure about that...Help me out cuase this is really bothering me.
Old Mar 22, 2002 | 12:37 PM
sil SE's Avatar
do a search for reseting ecu.
anyone get CEL problems after y pipe install?
Old Mar 22, 2002 | 12:52 PM
tm96max's Avatar
Go here: http://vbxmaxima.8m.com/ecu.html
and here: http://vbxmaxima.8m.com/ecudecoder.html
the second page will help you figure out what the problem is.
thanks vbxmaxima!!
Old Mar 22, 2002 | 01:12 PM
Re: Computer reset
i just found out that the o2 sensor is not hooked on...is it supposed to be hooked back on or is this the mechanic's fault.
Old Mar 22, 2002 | 01:30 PM
mzmtg's Avatar
Minister of Silly Walks
Re: Re: Computer reset
It is supposed to be be hooked up.
Hook it up, reset your ECU, then go kick your "mechanic" in the nuts.
Old Mar 22, 2002 | 01:34 PM
SuDZ's Avatar
Re: Re: Re: Computer reset
Which one of those helps the problems more? One will take care of the problem now and one will make sure it doesnt happen again.
SuDZ
Old Mar 22, 2002 | 01:54 PM
allright i did that...by resting the ECU u mean hooking the battery off and hooking it back on? Because the light is still on...
Old Mar 22, 2002 | 02:48 PM
Re: Computer reset
Hi there
OK
The problem has been fixed...thanks to all. For anybody that has questions about reseting the ECU i'll be glad to help out.
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
msellas
Sep 23, 2015 09:16 PM
ballerchris510
Sep 23, 2015 08:46 PM
Colossus
Sep 9, 2015 05:46 AM
