Crackling noise from the rear
Old Mar 22, 2002 | 12:55 PM
mingster's Avatar
I've got a 99SE/LE, and for the past year or so there's been this constant (and very annoying) crackling noise coming from the rear when I drive SLOWLY over uneven surfaces, as if the frame is crackling. I asked a mechanic and he said it may be the strut - but the car doesn't make any noise going through bumps, only when going through uneven surfaces - like when you go up a driveway at an angle, you know the frame is going to bend a little...
Any suggestions? Should I ask my dealer to "lubricate" the chassis (whatever that's supposed to mean).
Old Mar 22, 2002 | 01:06 PM
WoPhatMax's Avatar
Re: Crackling noise from the rear
i have a 95 GLE and had the same cracking noises. the noise on my car was due to both rear rotors being cracked. they only made the noise going slow on uneven surfaces (i.e. sloped drive thru window, driveways, etc). never heard the noise during normal driving. nissan service tech was amazed that the rotors had not blown apart - i saw them, they were bad
better have them looked at just in case.
Old Mar 28, 2002 | 11:22 PM
mingster's Avatar
Re: Re: Crackling noise from the rear
mm...no, not the rotors.
i read one of the notes about the lowering springs making those noise, any other comments on the possible cause?
thanks.
Old Mar 28, 2002 | 11:46 PM
emoore924's Avatar
could be...
creaking rubber suspension bushings. That'd be my guess. If there's anything that could be lubed in the rear (ok you people, DON'T go there), I would have it done.
Old Mar 29, 2002 | 05:54 AM
iwannabmw's Avatar
I had a crackling noise in the rear, I was able to trace it to the trunk liner on the sides of the car coming a little loose and banging in the metal. It drove me nuts until I fixed it.
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
doctorpullit
Sep 10, 2015 06:33 PM
ef9
Sep 5, 2015 11:18 PM
jfl330
Sep 4, 2015 01:44 PM
